Author Topic: Digispark not Responding in Ubuntu  (Read 1620 times)
Teleputer
« on: August 14, 2018, 12:41:34 am »
Heaven-I everyone  ;)
So i got my Digisparks working on Both my Macbook(Age:2006) and my Desktop Gaming computer(I58600k, 32GB) Then i tried to do it on my Ubuntu Desktop(I52500, 8GB, Model:Optiplex-970) and i got it to work and it does show up on the Booting period when i did
Teleputer@Teleputer-server:~$ lsusb
Bus 002 Device 005: ID 062a:415e Creative Labs
Bus 002 Device 019: ID 16d0:0753 MCS Digistump DigiSpark
Bus 002 Device 004: ID 1038:160e SteelSeries ApS
Bus 002 Device 003: ID 2001:3314 D-Link Corp.
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
But once i got the Arduino IDE to stop giving me errors it showed
Sketch uses 2810 bytes (46%) of program storage space. Maximum is 6012 bytes.
Global variables use 106 bytes of dynamic memory.
Running Digispark Uploader...
> Device search timed out
Once the Boot Period was over it ran the Program i uploaded earlier
Tell me what to Type and i will Verify and Execute it
Teleputer:~$ Thank you
Thank: command not found
Teleputer:~$ sudo Thank you
Thank you =)
[/font][/font][/font]
« Last Edit: August 14, 2018, 01:12:21 am by Teleputer »
