Author Topic: Cant compile for tiny85 - "ctags pattern is missing"  (Read 1961 times)
MrManor
« on: August 13, 2018, 11:05:27 am »
I'm bit lost here: feel free to redirect me to other info channels - but for now I have no idea on where search for help.
I have the Arduino IDE installed on my OpenSUSE 42.3 and it works with no problem - I can compile for - and program - all my original Arduino UNO boards with no problems.
klaus@raagi:~> rpm -qa | grep -i arduino
arduino-builder-1.3.25-5.7.x86_64
Arduino-1.8.5-14.2.noarch
arduino-hardware-1.8.5-14.2.noarch
I have now aquired some Attiny85 boards and try to follow the directions on http://digistump.com/wiki/digispark/tutorials/connecting. When I hit upload I get:
/usr/share/java/Arduino-1.8.5/arduino-builder -dump-prefs -logger=machine -hardware /usr/share/java/Arduino-1.8.5/hardware -hardware /home/klaus/.arduino15/packages -tools /usr/share/java/Arduino-1.8.5/hardware/tools/avr -tools /home/klaus/.arduino15/packages -built-in-libraries /usr/share/java/Arduino-1.8.5/libraries -libraries /home/klaus/Arduino/libraries -fqbn=digistump:avr:digispark-tiny -ide-version=10805 -build-path /tmp/arduino_build_241720 -warnings=all -build-cache /tmp/arduino_cache_727407 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/home/klaus/.arduino15/packages/arduino/tools/avr-gcc/4.8.1-arduino5 -prefs=runtime.tools.micronucleus.path=/home/klaus/.arduino15/packages/digistump/tools/micronucleus/2.0a4 -verbose /home/klaus/Arduino/1erst-sketch_aug12a/1erst-sketch_aug12a.ino
/usr/share/java/Arduino-1.8.5/arduino-builder -compile -logger=machine -hardware /usr/share/java/Arduino-1.8.5/hardware -hardware /home/klaus/.arduino15/packages -tools /usr/share/java/Arduino-1.8.5/hardware/tools/avr -tools /home/klaus/.arduino15/packages -built-in-libraries /usr/share/java/Arduino-1.8.5/libraries -libraries /home/klaus/Arduino/libraries -fqbn=digistump:avr:digispark-tiny -ide-version=10805 -build-path /tmp/arduino_build_241720 -warnings=all -build-cache /tmp/arduino_cache_727407 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/home/klaus/.arduino15/packages/arduino/tools/avr-gcc/4.8.1-arduino5 -prefs=runtime.tools.micronucleus.path=/home/klaus/.arduino15/packages/digistump/tools/micronucleus/2.0a4 -verbose /home/klaus/Arduino/1erst-sketch_aug12a/1erst-sketch_aug12a.ino
Using board 'digispark-tiny' from platform in folder: /home/klaus/.arduino15/packages/digistump/hardware/avr/1.6.7
Using core 'tiny' from platform in folder: /home/klaus/.arduino15/packages/digistump/hardware/avr/1.6.7
Detecting libraries used...
"/home/klaus/.arduino15/packages/arduino/tools/avr-gcc/4.8.1-arduino5/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections   -mmcu=attiny85 -DF_CPU=16500000L -DARDUINO=10805 -DARDUINO_AVR_DIGISPARK -DARDUINO_ARCH_AVR  "-I/home/klaus/.arduino15/packages/digistump/hardware/avr/1.6.7/cores/tiny" "-I/home/klaus/.arduino15/packages/digistump/hardware/avr/1.6.7/variants/digispark" "/tmp/arduino_build_241720/sketch/1erst-sketch_aug12a.ino.cpp" -o "/dev/null"
Generating function prototypes...
"/home/klaus/.arduino15/packages/arduino/tools/avr-gcc/4.8.1-arduino5/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections   -mmcu=attiny85 -DF_CPU=16500000L -DARDUINO=10805 -DARDUINO_AVR_DIGISPARK -DARDUINO_ARCH_AVR  "-I/home/klaus/.arduino15/packages/digistump/hardware/avr/1.6.7/cores/tiny" "-I/home/klaus/.arduino15/packages/digistump/hardware/avr/1.6.7/variants/digispark" "/tmp/arduino_build_241720/sketch/1erst-sketch_aug12a.ino.cpp" -o "/tmp/arduino_build_241720/preproc/ctags_target_for_gcc_minus_e.cpp"
Error compiling for board Digispark (Default - 16.5mhz).
I  have cranked compiler warnings up to All but it makes no difference.
After a IDE run, the result from last compile is a empty file. (/tmp/arduino_build_241720/preproc/ctags_target_for_gcc_minus_e.cpp)
But if I repeat the last compile line by hand - directly in bash prompt, the compile completes with no error, and the generated file is 4540 bytes.
Any ideas?
