Author Topic: Help out a noob?  (Read 1523 times)
rollerce
Help out a noob?
« on: July 15, 2018, 11:27:06 pm »
Playing around with an adafruit 16x8 matrix was hoping to run it using a Digistump.
Using the example available from the adafruit library, I get the following mess when trying to compile:
In file included from C:\Users\rolle\Documents\Arduino\libraries\Adafruit_LED_Backpack_Library\examples\matrix16x8\matrix16x8.ino:31:0:
C:\Users\rolle\Documents\Arduino\libraries\Adafruit_GFX_Library/Adafruit_GFX.h:107:25: error: '__FlashStringHelper' does not name a type
     getTextBounds(const __FlashStringHelper *s, int16_t x, int16_t y,
C:\Users\rolle\Documents\Arduino\libraries\Adafruit_GFX_Library/Adafruit_GFX.h:107:46: error: ISO C++ forbids declaration of 's' with no type [-fpermissive]
exit status 1
Error compiling for board Digispark (Default - 16.5mhz).
I'm using the default example, but I'll post the code here:
  This is a library for our I2C LED Backpacks
  Designed specifically to work with the Adafruit 16x8 LED Matrix backpacks
  ----> http://www.adafruit.com/products/2035
  ----> http://www.adafruit.com/products/2036
  ----> http://www.adafruit.com/products/2037
  ----> http://www.adafruit.com/products/2038
  ----> http://www.adafruit.com/products/2039
  ----> http://www.adafruit.com/products/2040
  ----> http://www.adafruit.com/products/2041
  ----> http://www.adafruit.com/products/2042
  ----> http://www.adafruit.com/products/2043
  ----> http://www.adafruit.com/products/2044
  ----> http://www.adafruit.com/products/2052
  These displays use I2C to communicate, 2 pins are required to
  interface. There are multiple selectable I2C addresses. For backpacks
  with 2 Address Select pins: 0x70, 0x71, 0x72 or 0x73. For backpacks
  with 3 Address Select pins: 0x70 thru 0x77
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include <Adafruit_GFX.h>
#include "Adafruit_LEDBackpack.h"
Adafruit_8x16matrix matrix = Adafruit_8x16matrix();
  Serial.begin(9600);
  Serial.println("16x8 LED Matrix Test");
  matrix.begin(0x70);  // pass in the address
static const uint8_t PROGMEM
  smile_bmp[] =
  { B00111100,
    B01000010,
    B10100101,
    B10000001,
    B10100101,
    B10011001,
    B01000010,
    B00111100 },
  neutral_bmp[] =
  { B00111100,
    B01000010,
    B10100101,
    B10000001,
    B10111101,
    B10000001,
    B01000010,
    B00111100 },
  frown_bmp[] =
  { B00111100,
    B01000010,
    B10100101,
    B10000001,
    B10011001,
    B10100101,
    B01000010,
    B00111100 };
  matrix.clear();
  matrix.drawBitmap(0, 0, smile_bmp, 8, 8, LED_ON);
  matrix.writeDisplay();
  delay(500);
  matrix.clear();
  matrix.drawBitmap(0, 8, neutral_bmp, 8, 8, LED_ON);
  delay(500);
  matrix.clear();
  matrix.drawBitmap(0, 0, frown_bmp, 8, 8, LED_ON);
  delay(500);
  matrix.clear();      // clear display
  matrix.drawPixel(0, 0, LED_ON);
  matrix.writeDisplay();  // write the changes we just made to the display
  delay(500);
  matrix.clear();
  matrix.drawLine(0,0, 7,15, LED_ON);
  delay(500);
  matrix.clear();
  matrix.drawRect(0,0, 8,16, LED_ON);
  matrix.fillRect(2,2, 4,12, LED_ON);
  delay(500);
  matrix.clear();
  matrix.drawCircle(3,8, 3, LED_ON);
  delay(500);
  matrix.setTextSize(2);
  matrix.setTextWrap(false);  // we dont want text to wrap so it scrolls nicely
  matrix.setTextColor(LED_ON);
  for (int8_t x=0; x>=-64; x--) {
    matrix.clear();
    matrix.setCursor(x,0);
    matrix.print("Hello");
    delay(100);
  matrix.setTextSize(1);
  matrix.setRotation(1);
  for (int8_t x=7; x>=-36; x--) {
    matrix.clear();
    matrix.print("World");
    delay(100);
  matrix.setRotation(0);
I have a feeling that the digistump might not be able to do this, but I'm not a coder, I just kinda mash stuff together with the hope that it works. Any advice? I read in a different post that the references to __FlashStringHelper needed to be commented out, but that resulted in an entirely new mess.
C:\Users\rolle\Documents\Arduino\libraries\Adafruit_GFX_Library/Adafruit_GFX.h:111:3: error: expected unqualified-id before 'virtual'
   virtual size_t write(uint8_t);
matrix16x8:34: error: cannot allocate an object of abstract type 'Adafruit_8x16matrix'
In file included from C:\Users\rolle\Documents\Arduino\libraries\Adafruit_LED_Backpack_Library\examples\matrix16x8\matrix16x8.ino:32:0:
C:\Users\rolle\Documents\Arduino\libraries\Adafruit_LED_Backpack_Library/Adafruit_LEDBackpack.h:94:7: note:   because the following virtual functions are pure within 'Adafruit_8x16matrix':
 class Adafruit_8x16matrix : public Adafruit_LEDBackpack, public Adafruit_GFX {
In file included from C:\Users\rolle\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\cores\tiny/Stream.h:24:0,
                 from C:\Users\rolle\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\cores\tiny/TinyDebugSerial.h:31,
                 from C:\Users\rolle\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\cores\tiny/WProgram.h:18,
                 from C:\Users\rolle\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\cores\tiny/Arduino.h:4,
                 from sketch\matrix16x8.ino.cpp:1:
C:\Users\rolle\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\cores\tiny/Print.h:73:20: note: virtual size_t Print::write(uint8_t)
     virtual size_t write(uint8_t) = 0;
matrix16x8:34: error: cannot declare variable 'matrix' to be of abstract type 'Adafruit_8x16matrix'
C:\Users\rolle\Documents\Arduino\libraries\Adafruit_LED_Backpack_Library/Adafruit_LEDBackpack.h:94:7: note:   since type 'Adafruit_8x16matrix' has pure virtual functions
exit status 1
