void setup() { // Pin Assignments. pinMode(2, INPUT); //Analog input 1 for TMP36 pinMode(0, OUTPUT);//Red LED pinMode(1, OUTPUT);//Relay to turn on Heater pinMode(3, OUTPUT);//Green LED pinMode(4, OUTPUT);//Yellow LED // Declare variables. int volts = 0; float Farenheit = 0;} void loop(){ volts= analogRead(1); //Read P2 voltage Farenheit = (((volts*5)/1024.0) - 0.5) * 100; //Convert voltage to centigrade. Farenheit = (Farenheit*9.0/5.0)+32.0; //Convert centigrade to farenheit. if (Farenheit >= 75) { digitalWrite(3,HIGH); digitalWrite(4,LOW); digitalWrite(0,LOW); digitalWrite(1,LOW); } else if (Farenheit < 75 && Farenheit > 68) { digitalWrite(4,HIGH); digitalWrite(3,LOW); digitalWrite(0,LOW); digitalWrite(1,LOW); } else if (Farenheit <= 68) { digitalWrite(0,HIGH); digitalWrite(1,HIGH); digitalWrite(4,LOW); digitalWrite(3,LOW); } delay(1000);}
