Author Topic: Cannot reprogram Digispark after keyboard example  (Read 1493 times)
gturkeli
« on: June 03, 2017, 12:25:04 pm »
Hello,
I am new to Digispark and microcontrollers. I tried the keyboard example and successfully installed it. Every time I plugged the board I receive the keystrokes I gave to Digispark.
But when I try to reprogram it my computer cannot detect the board. Here is what I did:
  • When I try to upload a new sketch Arduino IDE tells me to plug in the board.
  • I plug in the board.
  • Board behaves just like any time I plugged it in. Which is:
    • Hardware connected sounds
    • Hardware disconnected sounds
    • And the keystrokes stars
    • Arduino IDE gives timeout
I tried to make it visible to Arduino with these scenarios:
  • Digispark to directly to usb port with logitech kayboard + mouse(1 usb) usb plugged directly in another usb port on the computer
  • Digispark to hub with logitech kayboard + mouse(1 usb) usb plugged directly in its usual usb port on the computer
  • Digispark to hub with logitech kayboard + mouse(1 usb) usb plugged in to another port on the same hub
  • Digispark to directly to usb port without any other usb
  • Digispark to hub without any other usb
But I couldn't make it work. Do you have any suggestions?
