Sorry you feel that way @albertzerok... but the score of
happy satisfied Oak owners would probably disagree with you one that point. I have three running 24x7 just doing their job, and they work just fine. There are bugs for sure, but depending on what you want to do with them, these are easily worked around. At worst, these are just high quality ESP8266's, and you can use them as such with a cheap 3.3v logic level CH340 usb to serial adapter for programming (or use the Arduino ESP8266 OTA programming). You'll still get all the wifi and cloud stuff, just not particle.
Did you try contacting Erik directly via support (a-t) digistump (d-o-t) com???
@jbeaubien: So you did the
online update, and had trouble, but got it to update the system firmware to v10 / 1.0.5. But it didn't claim, so you've tried to
manual claim. Did it add to your particle account - is there an entry for it on your
console on particle? If there is no entry, there could be problem on the particle end.... I'm just not sure if the device needs to be online for that the claim to process, or it if should add, but simply be listed offline until it does connect.
If you have a 3.3v logic level usb to serial adapter, it might be worth re-loading the firmware manually just in case something went wrong with the update process and corrupt firmware was loaded. There are some simple instructions on an
easy serial firmware update on the wiki, and a link to the suggested sort of adapter on that page. They're only $1-2, and you'll find it handy when developing code on these sorts of devices as you easily load directly via the serial if you want to develop stuff faster, or simply have a serial terminal so you can output debugging messages.
