Author Topic: Is it possible to brick a Digispark with wrong uploader?  (Read 1919 times)
Bigstone
« on: May 17, 2017, 08:06:35 am »
As the subject says: Is it possible to brick a Digispark with wrong uploader?
I have tried to get my little one to work with my Win 10 machine but never got it to work properly so I was to try to upload some code from a XP machine instead. Right before I was to change to the other system I did one last test (the one you should never do it seems) this time I changed to use "USBTinyISP slow" in the "programmer" menu.. a desperate final test.. stupid ..  :-[
Now my Digispark will not show up at all in windows. It does not connect at all. All it does is to shine it's little power led. :P
Is it bricked beyond the oblivion or can I use a Arduino UNO to make it resurrect from the limbo flashing it with new firmware?
(Read some threads where it seemed to be rather complicated, if at all possible? Lots of failure. )
KASA
Re: Is it possible to brick a Digispark with wrong uploader?
« Reply #1 on: May 17, 2017, 01:02:45 pm »
Maybe you changed some fuses. You would need a high voltage programmer to undo this:
https://arduinodiy.wordpress.com/2015/05/16/high-voltage-programmingunbricking-for-attiny/
Maybe someone else has a better Idea.
KASA
