My code wont work at school, y? I bout a digispark, put in into ma pc, everything worked fine and still on my laptop i can write code on it. But when i connect the badusb to a school pc nothing happens the same on my laptop, but last i tested it worked on my pc. Can uu halp!!!11one
#include "DigiKeyboard.h"
// Delay between keystrokes
#define KEYSTROKE_DELAY 1000
#define KEY_ESC 0x29 // Escape
#define KEY_MODIFIER_LEFT_GUI 0x08
#define KEY_R 21
int iterationCounter = 0;
pinMode(0, OUTPUT); //LED on Model B
digitalWrite(0, LOW); // turn the LED off by making the voltage LOW
digitalWrite(1, LOW);
// don't need to set anything up to use DigiKeyboard
DigiKeyboard.update();
if (iterationCounter == 0) {
// this is generally not necessary but with some older systems it seems to
// prevent missing the first character after a delay:
// It's better to use DigiKeyboard.delay() over the regular Arduino delay()
// if doing keyboard stuff because it keeps talking to the computer to make
// sure the computer knows the keyboard is alive and connected
DigiKeyboard.delay(KEYSTROKE_DELAY);
DigiKeyboard.sendKeyStroke(KEY_ESC, MOD_GUI_LEFT);
DigiKeyboard.sendKeyStroke(KEY_R, MOD_GUI_LEFT); //run
DigiKeyboard.delay(500);
DigiKeyboard.print("cmd");
DigiKeyboard.print("start /max
http://88.---.---.254");
DigiKeyboard.sendKeyStroke(KEY_F11);
delay(1000);
iterationCounter++;
