This one's a work in progress - unless anyone already has something working?
Several problems already noted/resolved:
Pin declaration for I2S in Oak's core_esp8266_i2s.c, line 222, is incorrect:
pinMode(esp8266_gpioToPin[5], FUNCTION_1); //I2SO_BCK (SCLK)should read
pinMode(esp8266_gpioToPin[15], FUNCTION_1); //I2SO_BCK (SCLK)(I've already logged a pull request for this one.) Similar declaration on line 244 is correct.
Pin mappings: LRC - Oak pin 0 (ESP8266 pin 2)
BCLK - Oak pin 6 (ESP8266 pin 15)
DIN - Oak pin 3 (ESP8266 pin 3)
Next: I2S syntax is implemented differently in the ESP8266 <I2S.h> file than it is for plain-vanilla Arduino. Sample code will not work. Example:
| Arduino | ESP8266/Oak |
| I2S.begin(I2S_PHILIPS_MODE, sampleRate, 16); | i2s_begin(); i2s_set_rate(sampleRate); |
| I2S.write(sample); | i2s_write_sample(sample); |
Sample working sketch:#include <i2s.h>
const int frequency = 880; //frequency of square wave in Hz
int amplitude = 1000; //amplitude of square wave
const int sampleRate = 16000; //sample rate in Hz
const int halfWavelength = sampleRate / frequency; //half wavelength of square wave
int count = 0;
Particle.begin();
Particle.println("I2S simple tone");
i2s_begin(); //initialize i2s
i2s_set_rate(sampleRate); //set sample rate
if (count % halfWavelength == 0) amplitude = -1 * amplitude; //invert sample every half wavelength count multiple to generate square wave
i2s_write_sample(amplitude); //write sample twice, once for each channel
count++;
}Other issues: other more-sophisticated I2S WAV libraries I've found haven't worked yet, and need to be heavily adapted for the Oak. In particular, some use the math-avr library. This one is very different from the ESP8266 math library so a straight swap just doesn't work.
Will be posting more once I get WAV-playing working - again, unless anyone else has already done it?
