Hi
No, there isn't a resistor, perhaps I should try that on the next one, thought about it but was tring to make it as small as possible (it's an Iron Man Arc Reactor for my 5 y/o son, to be worn in the palm of his hand).
I'll try running this on just the digispark and see if it bricks it, before connecting the lights. I had tested the lights before I hooked them up with this code. Was using a colour changing code I found in some tutorial, can't find the link at the moment (am at work now). That did run using the digispark so that's why I'm blaming the code. I could upload the new code (the one that bricked them) after I had used the test code with the pixels connected.
The pixels are powered through the 5V pin on the digispark. I will then, once it works, power this using a 9V battery through the VIN pin.
JOhannes
