Author Topic: YL-69 / YL-38 Moisture Sensor  (Read 2646 times)
rnsi
« on: February 18, 2017, 05:10:25 pm »
I'm getting bad readings from a YL-69 moisture sensor with a Digispark. Using an Uno, I can get a range from 1023 down to around 100, but the same sensor on the Digispark gives me a range from 1023 (dry) down to around 980 (in a cup of water). Tried two different sensors with the same result. Tried to power the sensor from P2 and from the 5V pin on the side and from and external 5V source.
Has anyone had success with these sensors on a Digispark?
