Digistump Forums
Back to Digistump.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Login
Register
Digistump Forums
The Digispark
Digispark (Original) Support
Analog read with internal pull-up on pin 3
« previous
next »
Print
Pages: [
1
Author
Topic: Analog read with internal pull-up on pin 3 (Read 3272 times)
simonriskjaer
Newbie
Student, product dev. and electronics
on:
December 19, 2016, 01:22:38 pm »
I am trying to use pin 3 as an analog input. However, it seems the internal pullup is enabled when the port is in input mode. And so i keep having around 3V on it, rendering the ADC useless.
How do i disable the pullup?
Logged
Sr. Member
Re: Analog read with internal pull-up on pin 3
Reply #1 on:
December 19, 2016, 03:52:38 pm »
Why not use another analog pin (keep in mind the analog to physical pin mapping)? P3 is the only one with a default pull up.
http://digistump.com/wiki/digispark/tutorials/basics
Logged
simonriskjaer
Newbie
Reply #2 on:
December 19, 2016, 11:57:22 pm »
All other pins are in use for this project. I need P3 as an analog input.
There must be some way of using it as an analog input, i'm just not seeing it :-)
Logged
Sr. Member
Reply #3 on:
December 20, 2016, 12:40:43 am »
Looking at the schematic I see 2 possibilities, neither of which is ideal or perhaps feasible.
1. A cut and add on the board/schematic that switches out the external pull up for ADC input. (Not very practical)
2. Pull down the pin to ground effectively creating an external voltage divider which would lower the input with nothing attached. (Would have to experiment with this to see if feasable)
Unless I'm missing something obvious these are my first thoughts.
Are you sure you can't rearrange the pin usage to avoid P3 for ADC?
Logged
Print
Pages: [
1
« previous
next »
Digistump Forums
The Digispark
