Hello,
I purchased 20 Oaks and was able to connect to and configure 19 of them last March (had to use local server and change my routers channel, one of them never worked). I have had four of them in service since then and they have performed pretty reliably. Recently one of them stopped publishing events to the Particle Dashboard log. This particular Oak reports some data then goes to sleep for ten minutes then wakes and reports again. I see that it does still wake up every ten minutes (the light blinks briefly) and it shows up on the Particle device list with the correct last connection time.
I thought maybe it would help to upload my code to it again, but when I open the Oak CLI It says "No devices available." The other three Oaks continue to appear on the dashboard log, but I can't fix this one nor upload code to any new ones. I tried resetting it and went through the claiming procedure again, but still no luck.
Any ideas on how to fix this?
Thank you,
John
