Author Topic: MLX90614 Temp Sensor over I2C  (Read 5453 times)
digi_guy
« on: May 27, 2016, 09:28:13 am »
Hey guys,
I've been trying to get an infrared thermometer working over i2c, but currently my readings are way off. It's the MLX90614 from Adafruit, using their library from github
https://github.com/adafruit/Adafruit-MLX90614-Library
My guess is that it was written for a different arduino and needs to get ported for the Oak, but I'm not sure where to start with that. The output I get is
Ambient: 536870912 Temp: 1083192883
My second guess is that I'm not reading/writig the variables properly. When I changed the temps to integers I get
Ambient: 34 Temp: 35
If anyone has any thoughts I'd greatly appreciate hearing them.
Thanks
  This is a library example for the MLX90614 Temp Sensor
  Designed specifically to work with the MLX90614 sensors in the
  adafruit shop
  ----> https://www.adafruit.com/products/1748
  ----> https://www.adafruit.com/products/1749
  These sensors use I2C to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include <Adafruit_MLX90614.h>
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
  Particle.publish("Status", "Adafruit MLX90614 test");
  mlx.begin();
  double ambient =   mlx.readAmbientTempC();
  double tempC =   mlx.readObjectTempC();
  char buff[64];
  sprintf(buff, "Ambient: %d Temp: %d", ambient, tempC);
  Particle.publish("Ambiant", buff);
masrodjie
Re: MLX90614 Temp Sensor over I2C
« Reply #1 on: October 03, 2017, 04:38:10 pm »
I know it's old but maybe it can help for others.
You can use dtostrf function.
  adafruit shop
  interface
#include <Wire.h>
  mlx.begin();
  char ambient[64];
  char tempC[64];
  dtostrf(mlx.readAmbientTempC(), 2, 2, ambient);
  dtostrf(mlx.readObjectTempC(), 2, 2, tempC);
  char buff[64];
  sprintf(buff, "Ambient: %s Temp: %s", ambient, tempC);
  dtostrf(temp, 2, 2, msg);
