Hi all,
I am new to programming the arduino code, but have managed to get what I wanted to do working on an Uno..yay for me!..
But sadly I am unable to get it to work on a digispark attiny 16hz 5v board..
The program should detect EMF or any electricity around an antenna and sound an alarm,it works on uno but I get nothing from the Attiny, ..here is the code..
#define sample 300 //this is how many samples the device takes per reading
//more information for #define http://arduino.cc/en/Reference/Define
int inPin = A3; //analog 5
float val; //where to store info from analog 5
int pin12 = 1; //output of red led
int pin5 = 5;
int array1[sample]; //creates an array with number of elements equal to "sample"
//more information about arrays http://arduino.cc/en/Reference/Array
unsigned long averaging; //the program uses this variable to store the sum of each array it makes
Serial.begin(9600);
pinMode (5,OUTPUT);
for(int i = 0; i < sample; i++){ //this code tells the program to fill each element in the array we made with
array1[i] = analogRead(inPin); //information from the antenna wire coming out of the Arduino
averaging += array1[i]; //more information about for loops http://arduino.cc/en/Reference/For
} //the averaging line is simply saying: add averaging to whatever is in array position i
//averaging += array[i] is the same as averaging = averaging + array[i]
//for more information about += http://arduino.cc/en/Reference/IncrementCompound
Serial.println(val);
val = averaging / sample; //here the program takes the sum of all numbers in array1, and divides by the number of elements "sample"
val = constrain(val, 0, 100); //this constrains the variable value to between two numbers 0 and 100
val = map(val, 0, 100, 0, 255); //for more information about constrain http://arduino.cc/en/Reference/Constrain
analogWrite( pin12, val);
analogWrite( pin5, val);//the map statement tells the program to map out 0-100 to 0-255, 255 is
//the threashold of analogWrite for more information about map http://arduino.cc/en/Reference/Map
averaging = 0; //this line of code sets averaging back to zero so it can be used again
Hope someone can help me?, sorry if this is in the wrong place on the Forum .
