Author Topic: Sample code for oak rgb led needs corrected.  (Read 1927 times)
Mrb0y
« on: April 19, 2016, 04:20:45 pm »
I tried an edit but the code portions of the wiki are not editable. The first code sample for the rgb led wiki article has a redundant pin assignment. Should be pin 8 instead of the 7 again. Should be a simple fix for whom ever it is that can edit the code in the wikis.
jwhendy
Re: Sample code for oak rgb led needs corrected.
« Reply #1 on: April 19, 2016, 05:49:07 pm »
Odd you can't edit the code sections... when you click the pencil on the right hand side and scroll down, do you see something other than the attached image? The code is just text wrapped in <code> tags and should be editable.
Thanks for catching that. I wrote that entry and copied/pasted those lines, missing changing the last one. It's fixed now!
