Author Topic: Help with Particle claiming failure  (Read 1927 times)
cpetito
« on: April 19, 2016, 10:15:32 am »
UPDATE: See below.
I have three oaks.  They have all been upgraded to V1 firmware.
However, one of the three will not connect to the Particle dashboard.  I've used this Oak (Oak-01) since the beginning.  It's been through the various FWupgrades and I've programmed it via serial at various times.  No real problems using it.
I'm not sure what happened during the latest upgrade to V1 for this one device.
Here's the current state:
- unclaimed the device on Particle
- did a FW restore
- successfully upgraded to V1 - I have the triple blink led
- Oak Config says device is not connected to the Internet and indeed it is not showing up on Particle
- 192.168.0.1/particle shows "Connected"
- tried to manually claim the device on Particle, but get the response: "Could not claim device."
BTW, it doesn't matter if I get to the V1 upgrade via the config tool or via serial update.
Any pointers or suggestions will be appreciated.
UPDATE: Not sure why, but the board has been claimed in Particle.  However, I can not load a sketch via OTA update from the Adruino IDE nor oak.exe.
« Last Edit: April 19, 2016, 05:30:59 pm by cpetito »
