Author Topic: Defective Digispark?  (Read 4386 times)
randyh360
« on: January 24, 2013, 09:40:09 pm »
Let me start by thanking you for running such a great Kickstarter campaign! I love the Digispark and have already used it to build some projects that I've been wanting to complete for quite some time.
I have three Digisparks, two of them work great but the third seems to have a problem connecting to my computer. When I plug it in it briefly shows up in the device manager as an "Unknown Device" with the following status shown in the device property window:
Windows has stopped this device because it has reported problems. (Code 43)
The default sketch (flashing LED/cycling RGB) seems to work once the Digispark starts, just the USB connection seems to be non-functioning. Have you encountered this before? If not, can you recommend any steps to troubleshoot the problem?
Randy
« Last Edit: January 24, 2013, 09:43:19 pm by randyh360 »
Re: Defective Digispark?
« Reply #1 on: January 25, 2013, 11:09:58 am »
Randy - sounds like it likely is a dud - send me an email at support at digistump dot com and we'll get you fixed up.
Erik
randyh360
« Reply #2 on: January 26, 2013, 01:30:28 pm »
Well, it appears this problem was my own doing. I desoldered the headers and the Digispark started working. I must have used too much solder and bridged some of the pins. It might be a good idea to suggest that people test their Digisparks before soldering anything.  :)
« Last Edit: January 26, 2013, 01:32:56 pm by randyh360 »
