Author Topic: Breadboard Suggestions  (Read 6093 times)
brohan
Re: Breadboard Suggestions
« Reply #15 on: April 13, 2016, 05:29:38 am »
Cut the 6's in half, and glue 3 together?
« Reply #16 on: April 13, 2016, 08:54:52 am »
Or... 6 and 3 no cutting. I believe you can get both from Sparkfun, albeit for .50 each. A 10 pin reduced to 9 pin is probably the cheapest and easiest way to go.
« Reply #17 on: April 13, 2016, 09:03:29 am »
Whenever a cut is made a pin is lost - so cutting a 6 gives a 3 and a 2.  Also each cut end can take some trimming so it isn't too wide if put against another header.  An 8 could make two 3's - just put the cut edge on the outside. Solder (on the pins) is the glue :)
