Author Topic: [SOLVED] "This tool doesn't know how to upload... Device reports version as 2.0"  (Read 5597 times)
jwhendy
Update: I couldn't get over the fact that micronucleus was in a 2.0a4 labeled folder, thinking it must have been at least v2. I had even seen this recent post but it just didn't register that it might have the answer to my problem. After compiling from source I'm able to use micronucleus to upload manually with sudo. I think I have some more futzing to get it to work without root, but that's mentioned on the troubleshooting page, so I think I'll be alright. Sorry for the noise!
I just got my first Digisparks in the mail and am a bit confused on installing Digispark Pro required things on linux. I have arduino 1.6.8 installed and successfully installed the board, but am stuck on uploading. I get the following errors:
Warning: device with unknown new version of Micronucleus detected.
This tool doesn't know how to upload to this new device. Updates may be available.
Device reports version as: 2.0
I found a very similar error here but no one reported not being able to upload. The linux instructions suggest cloning the DigitumpArduino git repo and then copying ./hardware to the arduino hardware library... but there's no hardware directory in the DigistumpArduino repo!
$ cd ./digistump-avr
$ find ./ -name hardware
# nada
I appear to have what I'd expect in ~/.arduino15/packages/digistump/hardware/avr/1.6.7. The troubleshooting issues I've found seem to suggest not having permissions, incompatible USB drivers, or an outdated micronucleus. I don't think any of those is necessarily the case. I have a version in ~/.arduino15/packages/digistump/tools/micronucleus/2.0a4. It appears to find the board, but then disagree with something about it.
I have the board selected as "Digispark Pro (Default 16MHz)."
Any suggestions?
« Last Edit: March 31, 2016, 08:33:29 pm by jwhendy »
This is marked [SOLVED] - what was the solution?
jwhendy
It's in the update above, ie compiling micronucleus and replacing the default one that downloaded via the board manager process.
