Author Topic: A fashion problem  (Read 2506 times)
Necuacuam
A fashion problem
« on: March 27, 2016, 07:00:56 am »
Hi! This is Necuacuam from Many Places (in Spain right now).
I've been trying to connect my Oak for a month but unsuccessfully.
My first step: https://digistump.com/wiki/oak/tutorials/connecting but Oak update failed.
Then I tried https://digistump.com/wiki/oak/tutorials/local_update with the same result.
C:\oakupsrv-win32-r2>oakupsrv.exe
Preparing SSL key
Fetching https://oakota.digistump.com/firmware/firmware_v1.bin
Fetching https://raw.githubusercontent.com/digistump/OakSoftAP/master/config.htm
l
Using another WiFi capable device (NOT this machine) connect to your network, op
en a browser and go to: http://192.168.1.134:8080 and follow the instructions to
 update your Oak.
NOTE: You must use the config app at that address, it is configured specifically
 for this local update. Status messages will print here during the update. Do no
t close this window until you have finished updating.
2016-03-27 15:16:56 New connection from: 192.168.1.116
2016-03-27 15:16:56 Starting firmware transfer to: 192.168.1.116
2016-03-27 15:17:17 Connection lost to: 192.168.1.116
2016-03-27 15:17:17 Firmware request finished for 192.168.1.116 (Reason: [Failur
e instance: Traceback (failure with no frames): <class 'twisted.internet.error.C
onnectionLost'>: Connection to the other side was lost in a non-clean fashion: C
onnection lost.
2016-03-27 15:17:17 Early termination to: 192.168.1.116 (202752 bytes written, f
ail count = 1)
2016-03-27 15:17:17 Finishing firmware transfer to: 192.168.1.116 (1 transfers d
one)
My next step was https://github.com/digistump/OakRestore. The factory restore was a success.
Then I started all again...
- changing my wifi to 20MHz..
- then using my iPad to connect to Oak
- then using my Android to connect to Oak
- then using 4G instead of LAN
- then using 3.3V (on board) insted of 5v (usb)
The follows commands are working
http://192.168.0.1/version
http://192.168.0.1/device-id
http://192.168.0.1/scan-ap
and so on..
Any idea will be truly appreciated
Thank you for your time.
Nec
Re: A fashion problem
« Reply #1 on: April 01, 2016, 04:09:52 pm »
If you have a serial device to use Oak Restore with then you can upload the firmware update with that and skip the troublesome first update
http://digistump.com/wiki/oak/tutorials/serialupdate
