Author Topic: Robot over wifi with webpage  (Read 4230 times)
driffster
« on: March 22, 2016, 09:45:23 pm »
I been playing with the oak robot kit.
Now receiving commands from a web form :)
I use more or less the robot example code and added a few particle functions to send pseudo serial commands :
int SpeedValue = 1023;
  botInit();
   Particle.function("Movement",Movement);
   Particle.publish("Oak Report", "Start");
int Movement(String command)
    char buf[10];
    command.toCharArray(buf, 10) ;
    int firstChar = (int) buf[0];
    switch (firstChar)
      case 'f': //forward
        botForward( SpeedValue);
        return 1;
        break;
      case 'r': //reverse
        botReverse( SpeedValue);
        return 2;
        break;
      case 'd': //droite
        botRight( SpeedValue);
        return 3;
        break;
      case 'g': //gauche
        botLeft( SpeedValue);
        return 4;
        break;
      case 'D'://DROITE
        botHardRight( SpeedValue);
        return 5;
        break;
      case 'G': //GAUCHE
        botHardLeft( SpeedValue);
        return 6;
        break;
      case 's':
        botStop();
        return 7;
        break;
    return -1;
Also found a nice form on the particle docs to send POST commands directly in my browser:
<!--  Robot control -->
<!DOCTYPE>
<html>
  <body>
  <center>
   <br>
  <form action="https://api.particle.io/v1/devices/[DEVICE ID HERE]/Movement?access_token=[access token here]" method="POST">
    Tell your Robot what ro do!<br>
    <br>
    <input type="radio" name="args" value="f">forward
    <br>
    <input type="radio" name="args" value="G">Hard Left
    <input type="radio" name="args" value="g">Left
    <input type="radio" name="args" value="d">Right
    <input type="radio" name="args" value="D">Hard Right
    <br>
    <input type="radio" name="args" value="r">reverse
    <br>
    <br>
    <input type="radio" name="args" value="s">Stop motor
    <br>
    <input type="submit" value="Do it!">
  </form>
  </center>
  </body>
</html>
I have 0 experience in HTML, right now to make a bit efficient I'll get rid of the buttons and just put buttons, but I was wondering how I can make my browser not go to the particle report page (output of the function) ?
I plan to have some proximity sensor at some point and some encoders (well they are there but for now the data they output is not been used (got some serious bouncing going on).
« Last Edit: March 22, 2016, 09:48:33 pm by driffster »
theevl
Re: Robot over wifi with webpage
« Reply #1 on: March 26, 2016, 07:15:56 pm »
This reply is not related to a robot project, but i wanted to thank you for posting your codes!  Your //comments allowed me to modify your code into something that let's me make an web-controlled RGB LED.
thanks!
bcbrian
« Reply #2 on: April 03, 2016, 06:27:43 pm »
I am going to build on this. I am an avid web developer and think I could help a bit in this area. However I am very new to oak and iot so I might be posting on here for some direction :)
"Also found a nice form on the particle docs to send POST commands directly in my browser"
Do you have the link that explained how to do the post via the form?
« Last Edit: April 03, 2016, 06:29:42 pm by bcbrian »
driffster
« Reply #3 on: April 05, 2016, 04:53:07 pm »
Here is the link from the particle docs that point directly to the html code:
https://docs.particle.io/guide/getting-started/examples/core/#use
Aside from remote control, which is not great because of the 1 sec limit on input commands, I would love just to activate different behaviors in a more autonomous robot.. I will need to complement it with different sensors first.
