Any one that can point me as to what i need to do?
I am unable to upload any code to my OAK, does not matter the size of the code, i get the following:
Using config file at: C:\Users\XXXX\AppData\Roaming\oak\config.json
Sending file to cloud, to flash to device...
Flashing to: Test Unit (Device ID: abcdefghijklmnopqrstuvwx) - NOT my ID, but i have the correct id as per the ID in Particle
Flashing............................................................
Flash timeout - flash failed.
(Solved)
So i did the
https://github.com/digistump/OakRestore again after installing particle on my phone to confirm that i do not have bad connection.
After the 3rd restore.... Joy..... i can now program my Oak.
Still have no idea why this did not work before, the serial info from the Oak did not point to any issue, but it took multiple restores to get it working.
