Author Topic: Digispark Servo & Button Combination  (Read 2681 times)
joshtubb
« on: March 08, 2016, 02:40:27 pm »
I created a string of code for my arduino uno which allows me to rotate my servo by pushing one of two buttons. I can push either of the buttons to rotate it either CW or CCW. I wanted to be able to use this same code on the digispark, but I cannot work out how to get it to work. I believe this is because it does not recognise the servo.h library. What can I do to make this work?
The code is as follows:
#include <Servo.h>
const int servoPin = 12;
const int buttonA = 9;
const int buttonB = 8;
int buttonState = 0;
int directionState = 0;
Servo servo;
int angle = 0;   // servo position in degrees
  servo.attach(servoPin);
  pinMode(servoPin, OUTPUT);
  pinMode(buttonA, INPUT_PULLUP);
  pinMode(buttonB, INPUT_PULLUP);
  buttonState = digitalRead(buttonA);
  if (directionState == 0)
    if (buttonState == LOW)
      directionState = 1;
      for(angle = 0; angle < 180; angle++)
        servo.write(angle);
        delay(1);
  else if (directionState == 1)
      directionState = 0;
      for(angle = 180; angle > 0; angle--)
        servo.write(angle);
        delay(1);
  buttonState = digitalRead(buttonB);
      directionState = 1;
        servo.write(angle);
        delay(1);
      directionState = 0;
        servo.write(angle);
        delay(1);
What I have tried is to replace
#include <Servo.h>
Servo servo;
with
#include <SoftwareServo.h>
SoftwareServo servo;
const int servoPin = 1;
const int buttonA = 2;
const int buttonB = 3;
Please help, I am quite new at arduino.
