Author Topic: Question about a USB keyboard emulator.  (Read 6420 times)
H3nk
« on: February 09, 2016, 02:24:50 am »
I've built this thingy:http://www.practicalarduino.com/projects/virtual-usb-keyboard
and it works a treat, but I want to send a character with 2 control codes, and that doesn't work.
For example shift + ctrl + x.
UsbKeyboard.sendKeyStroke(KEY_B,MOD_CONTROL_LEFT) works, but
UsbKeyboard.sendKeyStroke(KEY_B,MOD_CONTROL_LEFT, KEY_ARROW_LEFT)
does not work, and I get the following error message:
UsbKeyboardtest.ino: In function 'void loop()':
UsbKeyboardtest:41: error: no matching function for call to 'UsbKeyboardDevice::sendKeyStroke(int, int, int)'
D:\arduino-1.0.5-r2\libraries\UsbKeyboard/UsbKeyboard.h:153: note: candidates are: void UsbKeyboardDevice::sendKeyStroke(byte)
D:\arduino-1.0.5-r2\libraries\UsbKeyboard/UsbKeyboard.h:157: note:                 void UsbKeyboardDevice::sendKeyStroke(byte, byte)
I think it's got something to do with the following in Usbkeyboard.h:
void sendKeyStroke(byte keyStroke) {
    sendKeyStroke(keyStroke, 0);
  void sendKeyStroke(byte keyStroke, byte modifiers) {
    while (!usbInterruptIsReady()) {
      // Note: We wait until we can send keystroke
      //       so we know the previous keystroke was
      //       sent.
    memset(reportBuffer, 0, sizeof(reportBuffer));
    reportBuffer[0] = modifiers;
    reportBuffer[1] = keyStroke;
I have already tried a few things, but my knowledge of C++ is very minimal, so it doesn't surprise me that it doesn't work. I need to add an extra modifier.
The only thing I want, is to send a ctrl + uppercase character, but since the HID tables only has lowercase, I need to send a shift too, and that's where it goes wrong.
I have only posted snippets of the code, I assume that others are in the know about this project.
I have also found another Usbkeyboard.h where the press command is implemented, but that also doesn't work.
In some way I'll have to add an extra byte modifier to the following line, but what I try, I only get errors. >:(
Thanks in advance for helping me out.
