Author Topic: Windows 7 driver cannot be found for digiUSB  (Read 2546 times)
Allinbits
« on: February 04, 2016, 08:29:57 am »
What Win 7 (32 bit) driver do I need for digiUSB?  The one supplied with the standard install does not seem to be recognised as the correct driver.
I am trying to set-up serial comms for a digispark.  I am able to program it with Arduino IDE 1.6.6 and have successfully uploaded the example program digisparkCDC/print :-)
With the digispark removed, I then ran dpinst32.exe in the DigiUSB Windows Driver folder, which installed driver libusb-win32 DigiUSB 1.2.6.0
On plugging the device back into the USB port Windows attempted to install a driver for the device but failed with error 'driver not found'
I then located the Digispark in  Device Manager which reported the device as 'not working' - not surprising if there's no driver.  I then attempted to manually install the driver with Device Manager by pointing the installer at a folder containing libusb-win32-bin-1.2.6.0 which I had downloaded separately. I received the same error, 'driver not found'
I'm stumped if you excuse the pun.  What else should I try?
« Last Edit: February 04, 2016, 08:31:57 am by Allinbits »
