Author Topic: DigiUSB help  (Read 7589 times)
atrueresistance
DigiUSB help
« on: January 19, 2013, 01:38:59 pm »
Hello I'm currently using windows 7 64bit. For programming my Digispark. I have some questions however on the DigiUSB library. When I upload the Echo example and then use monitor.exe to view and send commands this works flawlessly. However If I use the program I'm converting from Arduino to Digispark I get a nasty No DigiUSB Device Detected. Here is the code.
#include
#include
#define RELAY_PIN 1
#define ONE_WIRE_BUS 5
//#include                  // I2C Master lib for ATTinys which use USI - comment this out to use with standard arduinos
//#include          // for LCD w/ GPIO MODIFIED for the ATtiny85
#define GPIO_ADDR     0x27
#define DS18B20_ID 0x28
OneWire oneWire(ONE_WIRE_BUS);
OneWire ds(ONE_WIRE_BUS);
//LiquidCrystal_I2C lcd(GPIO_ADDR,16,2);  // set address & 16 chars / 2 lines
void setup(void)
  pinMode(RELAY_PIN, OUTPUT);
  DigiUSB.begin(); // open DigiUSB
  //TinyWireM.begin();                    // initialize I2C lib - comment this out to use with standard arduinos
  //lcd.init();                           // initialize the lcd
  //lcd.backlight();                      // Print a message to the LCD.
  //lcd.print("Digispark!");
void loop(void)
    float target = 63;
    float temp =  62;   //getTemperature();     need to debug this function
    if(temp >= target){
      digitalWrite(RELAY_PIN, LOW);
      DigiUSB.println("Heater Off");
    else if(temp < target){
      digitalWrite(RELAY_PIN, HIGH);
      DigiUSB.println("Heater On");
      DigiUSB.println(temp);
      delay(6000);
float getTemperature(){
 float temp;
 byte i;
 byte present = 0;
 byte data[12];
 byte addr[8];
 //find a device
 if (!ds.search(addr)) {
   ds.reset_search();
   return 0.00;
 if (OneWire::crc8( addr, 7) != addr[7]) {
  return 0.01;
 if (addr[0] != DS18B20_ID) {
  return 0.02;
 ds.reset();
 ds.select(addr);
 // Start conversion
 ds.write(0x44, 1);
 // Wait some time...
 delay(850);
 present = ds.reset();
 ds.select(addr);
 // Issue Read scratchpad command
 ds.write(0xBE);
 // Receive 9 bytes
 for ( i = 0; i < 9; i++) {
  data = ds.read();
 ds.reset_search(); //reset the only 1 device on
 // Calculate temperature value
 temp = ( (data[1] << 8) + data[0] )*0.0625;
 temp = (temp * 9/5)+32;
 return temp;
I'm a little confused as to why the Echo program works, and mine doesn't. If someone could enlighten me? Please.
« Last Edit: January 19, 2013, 01:38:59 pm by atrueresistance »
atrueresistance
DigiUSB help
« Reply #1 on: January 19, 2013, 01:46:38 pm »
Seems as I forgot DigiUSB.refresh(); I have found a different problem now. It seems to have an overflow somewhere. Could this be the Monitor.exe? http://imgur.com/NtmwGy9
DigiUSB help
« Reply #2 on: January 19, 2013, 02:14:14 pm »
This overflow is occurring in the library I believe - we\'re working on why this occurs sometimes and not others - a good alternative for now is to only send data over USB when it is requested - see the DigiScope example for one approach to this - basically it waits until anything is sent to it and then sends a reading
ntsarb
Re: DigiUSB help
« Reply #3 on: September 02, 2017, 09:45:51 pm »
Has this been fixed? If so, from which version? Thanks.
