Definitely not the first, nor the last time, I'll burn up something. It just seemed too fragile IMO, to the point I'd like to blame the design more than my admitted negligence.
It's not like I hooked up a lab's PSU and provided lot's of power, in the wrong direction, with the wrong components - like so many of us did our first year of Electronics Fundamentals.
Guess I'm just happy to know it was a Schottky diode and not the µC.
** I found this schematic:
https://s3.amazonaws.com/digispark/DigisparkSchematicFinal.pdfLooks like a less-than-ideal Zener diode could have been chosen for voltage regulation - which potentially failed.
Although, I did look up the Schottky diode, MBR0520LT1, and I'm willing to bet it is in fact the problem.
** Just confirmed with a multimeter, and by bypassing the component, which made the board work again.
Conveniently located in the corner, should be easy to swap out with a better one.
I can post results if anyone else has the same problem, or would like to know what I replace it with.
http://www.datasheetarchive.com/MBR0520LT1-datasheet.html#
