Author Topic: Relay shield damaged?  (Read 6082 times)
vicary
« on: January 16, 2013, 05:35:07 am »
I have just assembled a relay shield, and try to test it with an 5V adapter before going into codes.
I found the only leads that are connected but with resistance (about 1K), and tried to connect the 5V power between those two leads. But all I got is a short circuit and the adapter's fuse popped.
Don't know if it is normal to this specific relay model, I got some clicking sound when I gently shake it, which I had never experienced with other 5V relays.
I don't want a single one of my DigiSparks to take the risk for this short circuit test...
Could anybody gives me some suggestion to this?
« Last Edit: January 16, 2013, 05:35:07 am by vicary »
« Reply #1 on: January 16, 2013, 11:07:26 am »
On the bottom of the shield there are two pins sticking through from the relay next to the 3 pin header connector - can you measure the resistance between these two points? It should be around 100 ohm (and fluctuate).
vicary
« Reply #2 on: January 16, 2013, 07:41:49 pm »
I measure a range between 54-59 ohms.
I switched to a salvaged computer PSU, but it just think the coil is a short circuit and shuts off.
Sergio
« Reply #3 on: January 16, 2013, 08:10:45 pm »
Any chance you soldered the diode backwards?
« Reply #4 on: January 16, 2013, 09:26:33 pm »
Sergio - good point - vicary - is the diode in the right direction? (the photo is showing the correct direction)
also is the transistor in the correct orientation?
vicary
« Reply #5 on: January 16, 2013, 09:35:06 pm »
I oriented the strip as the PCB said so, and the flat side of transistor too.
BTW how can I post a photo here?
« Reply #6 on: January 16, 2013, 10:17:35 pm »
click attach a file
vicary
« Reply #7 on: January 16, 2013, 10:44:31 pm »
Can't find the attach button, but it seems HTML works here.
just checked the wiki again, nothing wrong with the orientation I guess.
EDIT: Use attachment instead in the new forum.
« Last Edit: January 21, 2013, 10:16:23 am by vicary »
« Reply #8 on: January 16, 2013, 11:53:22 pm »
looks right - how much of a rattle do you get with the relay? I can hear a very faint click when I shake mine
I see three possibilities
1) Bad relay
2) Bad diode
3) The relay leads got to hot when soldering and melted the coil
vicary
« Reply #9 on: January 17, 2013, 12:14:20 am »
The clicking is not too loud, surely not the coil fell off. I was actually suspecting a loosen switch.
1. It is suspectable.
2. With the diode soldered, I measured a forward voltage of 097 in both ways.
3. Quite confident at this, I did two SMD motor shields before this. Sturdy hands and quick work guaranteed. ;)
« Reply #10 on: January 17, 2013, 01:41:47 am »
send me an email at support at digistump dot com and we\'ll get things worked out for you
