Author Topic: lcd shield backlight  (Read 3371 times)
serchend
« on: January 15, 2013, 06:15:39 am »
I am unable to get the backlight to turn on on the lcd shield. It works fine otherwise.
i have tried the “¬” command and it has no results.
« Last Edit: January 15, 2013, 06:16:02 am by serchend »
« Reply #1 on: January 15, 2013, 11:19:40 am »
@serchend - on the back of the LCD unit there are two right angle pins with the label LED above them - these should have a jumper on them, if they don\'t the backlight will be off. If they do not have a jumper check the packaging if you still have it or you can bend them together and put a bit of solder between them (try bridging them first to see if it works)
serchend
« Reply #2 on: January 15, 2013, 11:48:45 am »
that would be it thank you.
barnacleBudd
Re: lcd shield backlight
« Reply #3 on: February 06, 2013, 05:20:56 pm »
