Author Topic: Assertion failed: res >= 6  (Read 3644 times)
Robert
« on: May 16, 2015, 08:11:45 pm »
Anyone know how to get a pro beta to work using the latest greatest drivers/IDE from the wiki?
i renamed all my old arduino folders and whatnot, did an install from a freshly download package from the wiki and got this trying to upload basic start sketch:
Sketch uses 936 bytes (6%) of program storage space. Maximum is 14,844 bytes.
Running Digispark Uploader...
Assertion failed: res >= 6, file library/micronucleus_lib.c, line 69
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
As a sanity check, I tried the same on a brand new machine, never had any arduino stuff on it, and same problem.
Then I tried pulling out my old Surface pro which I had used when this was still in beta, and it works there with the nightly build that was recommended at the time.
For reference, my first and main machine is a win 7, the new laptop is 8.1, and the surface pro, I'm not sure, but I think also 8.1 all 64bit
I also got a pop up with the following info:
Problem signature:
  Problem Event Name:   APPCRASH
  Application Name:   micronucleus.exe
  Application Version:   0.0.0.0
  Application Timestamp:   54080dc2
  Fault Module Name:   msvcrt.dll
  Fault Module Version:   7.0.7601.17744
  Fault Module Timestamp:   4eeaf722
  Exception Code:   40000015
  Exception Offset:   0006680c
  OS Version:   6.1.7601.2.1.0.256.1
  Locale ID:   4105
  Additional Information 1:   7c2e
  Additional Information 2:   7c2e4fb6ef55e9e536c75974980d7a45
  Additional Information 3:   f801
  Additional Information 4:   f801d46c2cd61132c8eb35784a2cd219
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
I would really appreciate any help. I am dead in the water here on my main systems.
Re: Assertion failed: res >= 6
« Reply #1 on: June 23, 2015, 01:49:00 pm »
Do you have a second Digispark Pro you can test? The Beta firmware was not as final as the "final" firmware, and this could be a related issue showing up. Happy to send you a non-Beta if you'd like and don't have one: support@digistump.com
