Okay, I dont' know if I have a dead board or just don't know what is going on. I built the BLE shield and plugged it in Then I tried loading the following sketch:
// initialize serial:
Serial.begin(9600);//open connection to serial module
Serial.write("AT+MODE2"); //Turns on the ability to communicate using AT commands via bluetooth
delay(1000);
Serial.println("HelloWorld");
delay(1000);
However, I do not see the bluetooth board when I try to scan from my phone. I also don't see a lit LED on the board which it looks like there is one.
Am I missing something? Do I need to send other commands/api calls to initiate the board and put it in pairing mode? The tutorial for the board is pretty limited and the sketch there requires a product I don't have which makes no sense (startup examples in tutorials shouldn't have dependencies on non-related products!) Regardless, there is no discussion of how to pair the device.
I have doublechecked the soldering and it looks fine. One other possible issue is the board came with 3 headers: two 9 pin and one 3 pin. Both
the 9 pin have long leads so they can be attached to the sockets of the digispark pro beneath it but the 3 pin header had short pins so it does NOT attach to the 3 pin header on the Digispark pro. Is that a problem? I used this since it is what came in the robot kit. However, if i need to buy a long 3 pin header I can do that.
Please let me know if I need to return the board and get a new one.
thanks,
Tozz88
