The Digispark > Digispark Projects
Tutorial: Convert a Digispark in to a LittleWire AVR/PIC programmer and IO multitool, or ttl serial
gogol:
i just described my FUSE-resetter, which makes all those attinys again visible for littlewire, when something went wrong with the fuses!
littlewire is just a great possibility to use out-of-the-box attiny for projects, where you need no USB.
regards
Bluebie:
I've just released an update to my ruby library called 'littlewire' which provides access to most of littlewire's features in ruby. One of the more interesting additions is that now it includes a commandline utility called 'littlewire.rb' which has an install command. Enter 'littlewire.rb firmwares' to see which firmwares are available, then run 'littlewire.rb install latest' for instance to install the most recent version of littlewire on to your digispark. It does the upload using a ruby implementation of the micronucleus bootloader upload app, so it doesn't need to compile any binaries or have access to your Digispark Arduino IDE. You don't need to fuss around with hex files or any of that, and when installed properly it's available globally on your computer. It requires ruby 1.9 or 2.0 to work.
If you happen to have a digispark with a nunchuck shield and a nunchuck, I highly recommend installing 'latest-beta' (or '1.3' if that's out when you're reading this) then running `littlewire.rb racer`. Let me know what you think! I had fun making it ^_^
kehribar:
Hi All,
Using Digisparks as a Littlewire got so much easier :)
http://digistump.com/products/101
http://digistump.com/products/100
http://digistump.com/products/99
Take a look at this wiki entry for detailed information: http://digistump.com/wiki/digispark/tutorials/littlewire
If you have any questions, feel free to ask.
Best,
ihsan.
bobricius:
hi,Where is described what is new in 1.3 firmware?
kehribar:
--- Quote from: bobricius on November 20, 2013, 01:54:00 pm ---hi,Where is described what is new in 1.3 firmware?
--- End quote ---
There are couple of bugfixes around mainly I2C functionality. Also I deleted the experimental pic24f programming feature to open up more space. There were reported issues that littlewire firmware wasn't small enough to be used with some versions of the micronucleus bootloader.
If you want, you can track the changes from the repo itself: https://github.com/littlewire/Little-Wire/commits/master
Best,
ihsan.
Navigation
[0] Message Index
[*] Previous page
Go to full version
