Hi all,
I've leveraged the work performed by the Punnie (see
http://digistump.com/board/index.php/topic,1000.0.html) and the authors of the DigiJoystick library to create a dual SNES controller to USB game controller adapter.
The adapter allows 2 SNES controllers to be connected to a PC. One game controller is recognized by the operating system. Controller 1 uses the X/Y axis and buttons 1 through 8. Controller 2 uses the SLIDER/ZROT axis and buttons 9 through 16.
Code below. Enjoy!
//DigiJoystick test and usage documentation
//Good Documentation of the SNES Controller (German) http://www.rn-wissen.de/index.php/SNES_Controller
#include "DigiJoystick.h"
/* Some data about the SNES controller protocol from http://www.gamefaqs.com/snes/916396-super-nintendo/faqs/5395
SNES Controller pinout
| (1) (2) (3) (4) | (5) (6) (7) |
Pin Description
1 +5v
2 Data clock
3 Data latch
4 Serial data
5 ?
6 ?
7 Ground
SNES Controller Communication Protocol
|<------------16.67ms------------>|
12us
Data Latch --- -----------------/ /----------
Data Clock ---------- - - - -/ /---------------- -
1 2 3 4 1 2
Serial Data ---- --- ----/ / ---
(Buttons B --- --- --- ----------
& Select norm B SEL norm
pressed). low low
12us
Clock Cycle Button Reported
1 B
2 Y
3 Select
4 Start
5 Up on joypad
6 Down on joypad
7 Left on joypad
8 Right on joypad
9 A
10 X
11 L
12 R
13 none (always high)
14 none (always high)
15 none (always high)
16 none (always high)
For two SNES controllers to be connected to the digispark (rev 2 model), the following connection/wiring scheme was used:
SNES Controller 1 Pin SNES Controller 2 Pin Digispark Pin
1 1 5V
2 2 P5*
3 3 P2
4 P0**
4 P1**
7 7 GND
*Originally, I used pin P2 as clock and P5 as latch, but perhaps due to electrical characteristics, when a second controller was plugged in, multiple button presses were seen on both controllers and behavior was unexpected. The adapter behaved as expected when P2 was latch and P5 was clock.
**For my rev 2 digispark, I cut out the LED attached
to pin P1 (so as to not interfere with the SNES data
communications). Those with rev B digispark would
cut out the LED attached to pin P0.
When connected to a PC, the controller adapter will show up as one 6 axis, 16 button controller.
The X/Y axis and buttons 1 through 8 correspond to the first SNES controller.
The SLIDER/ZROT and buttons 9 through 16 correspond to the second SNES controller.
The button mapping is as follows (corresponds to the order in which buttons are clocked out of the SNES controller):
Button 1 => SNES B
Button 2 => SNES Y
Button 3 => SNES Select
Button 4 => SNES Start
Button 5 => SNES A
Button 6 => SNES X
Button 7 => SNES L
Button 8 => SNES R
boolean pinState = false;
int clockPin = 5; // Digispark pin number for both SNES controllers' clock pin
int latchPin = 2; // Digispark pin number for both SNES controllers' latch pin
int dataPin1 = 0; // Digispark pin number for SNES controller 1's Data pin
int dataPin2 = 1; // Digispark pin number for SNES ontroller 2's Data pin
uint16_t controller1Register = 0x0000; // 16 bit number to hold the 8 button values and 4 directions of SNES controller 1
uint16_t controller2Register = 0x0000; // 16 bit number to hold the 8 button values and 4 directions of SNES controller 2
uint8_t usbGameControllerRegisterLOW = 0x00; // button status for controller 1 will eventually be stored here
uint8_t usbGameControllerRegisterHIGH = 0x00; // button status for controller 2 will eventually be stored here
pinMode(clockPin,OUTPUT); // The digispark controls the clock pin
pinMode(latchPin,OUTPUT); // The digispark controls the latch pin
pinMode(dataPin1,INPUT); // The digispark reads the value of the data pin for SNES controller 1
digitalWrite(dataPin1,HIGH); // to enable the internal pull up resister (so buttons are off when no controller is plugged in)
pinMode(dataPin2,INPUT); // The digispark reads the value of the data pin for SNES controller 2
digitalWrite(dataPin2,HIGH); // to enable the internal pull up resister (so buttons are off when no controller is plugged in)
digitalWrite(clockPin,HIGH); // clock is initially set high
digitalWrite(latchPin,LOW); // latch is initially set low
// All axis are set to the neutral position
DigiJoystick.setX((byte) 0x80);
DigiJoystick.setY((byte) 0x80);
DigiJoystick.setXROT((byte) 0x80);
DigiJoystick.setYROT((byte) 0x80);
DigiJoystick.setZROT((byte) 0x80);
DigiJoystick.setSLIDER((byte) 0x80);
// Initalize both SNES controllers by setting latch high for 12 uSeconds
digitalWrite(latchPin, HIGH);
delayMicroseconds(12);
digitalWrite(latchPin, LOW);
// We first read the controller button status into our 16 bit controller registers
for(int i=0; i<16; i++) {
delayMicroseconds(6);
digitalWrite(clockPin, LOW);
// read and store the button status for controller 1
pinState=!digitalRead(dataPin1);
if(pinState){
controller1Register |= (0x01<<i);
}else{
controller1Register &= ~(0x01<<i);
// read and store the button status for controller 2
pinState=!digitalRead(dataPin2);
if(pinState){
controller2Register |= (0x01<<i);
}else{
controller2Register &= ~(0x01<<i);
digitalWrite(clockPin, HIGH);
// Now that we have the button status for both controllers, we now set the appropriate
// USB HID controller buttons and axis
// controller 1
usbGameControllerRegisterLOW = (char)(controller1Register & 0x000F) | (char)((controller1Register & 0x0F00) >> 4);
// controller 1 x-axis
if(controller1Register & 0x0040)
// left was pressed
DigiJoystick.setX((byte) 0x00);
else if(controller1Register & 0x0080)
// right was pressed
DigiJoystick.setX((byte) 0xFF);
else
// D-Pad is centered in the X direction
// controller 1 y-axis
if(controller1Register & 0x0020)
// down was pressed
DigiJoystick.setY((byte) 0xFF); // y-axis is flipped. FF is down, 00 is up
else if(controller1Register & 0x0010)
// up was pressed
DigiJoystick.setY((byte) 0x00);
else
// D-Pad is centered in the Y direction
// controller 2
usbGameControllerRegisterHIGH = (char)(controller2Register & 0x000F) | (char)((controller2Register & 0x0F00) >> 4);
// controller 2 x-axis
if(controller2Register & 0x0040)
// left was pressed
DigiJoystick.setSLIDER((byte) 0x00);
else if(controller2Register & 0x0080)
DigiJoystick.setSLIDER((byte) 0xFF);
else
// controller 2 y-axis
if(controller2Register & 0x0020)
// down was pressed
DigiJoystick.setZROT((byte) 0x00);
else if(controller2Register & 0x0010)
// up was pressed
DigiJoystick.setZROT((byte) 0xFF);
else
DigiJoystick.setButtons((char) usbGameControllerRegisterLOW , (char) usbGameControllerRegisterHIGH);
DigiJoystick.delay(14); // used to be 16. changed to 14 to compensate for extra instructions performed when translating controller registers to USB gamepad buttons/axis
