Author Topic: Can't upload sketch to Digispark  (Read 32745 times)
Re: Can't upload sketch to Digispark
« Reply #15 on: February 06, 2013, 11:11:01 am »
AlanSE - I apologize for misunderstanding where the error was occurring, we see a ton of people with that error who aren't unplugging it first.
Have you tried an extension cable and/or hub? It sounds like all of these could be related to the Digispark not having a good connection both the error during upload not recovering (the error at 80% is normal for how some computers handle the USB, but it should always recover itself) and the crashing of the program and device issues.
Does this occur with one or multiple Digisparks? If you have others and haven't yet, can you test them as well?
Erik
GuzWaatensensen
« Reply #16 on: February 06, 2013, 12:35:25 pm »
Um, i'm on a Mac though. I can verify however that using an unpowered USB Hub solved the problem in my case. Hope you'll eventually uncover what's the problem behind that...
hardillb
« Reply #17 on: February 06, 2013, 01:55:51 pm »
Hi thanks for the feed back,
If it helps to track things down, I'm running up to date Fedora 17 x86_64 on a Lenovo w500 ThinkPad
I tried it with a basic un-powered hub today, but I will try with a powered one when I'm back in the office tomorrow.
I have managed to get the DigiBlink code loaded via my Windows 7 machine tonight so I've managed to start playing, but I getting it all working on Linux would be great.
hardillb
« Reply #18 on: February 07, 2013, 01:37:04 am »
I can confirm that plugging the digispark in via the powered hub in my monitor has allowed me to upload the Start blink sketch with Linux.
Thanks for the pointer
« Reply #19 on: February 07, 2013, 02:05:33 am »
hardlib - wonderful that you got it working! still a puzzle as to why some linux distros work with it only through a powered hub...
AlanSE
« Reply #20 on: February 07, 2013, 07:21:17 am »
Consider my previous posts to be using a computer named "A".  I've tested it out on 3 computers now, and they all work at least some of the time.  In case you're going to ask, yes, I'm changing the timing of the blinking sketch each time so that I can confirm "runs with old sketch" or "runs with new sketch", because obviously it will boot up and run its old program with the USB power even if it's not doing anything with data.  This is the shield on the digispark.
Here are the most important specs of the different computers:
  • Comp A: 64-bit Windows 7, a 64-bit machine, desktop
  • Comp B: 32-bit Windows 7, a 32-bit machine, netbook
  • Comp C: 32-bit Windows XP, a 64-bit machine, desktop
To summarize my hypothesis, A had problems with both the connection and software.  Like I outlined, there were two hangup points that still occur, and I think this is connection, and then software, but I leave it open for others to disagree with me.  The thing never worked with a passive USB extension cord and I was still jiggling it a lot when it was plugged directly into the back.
With Comp B, the netbook, I put the software on the computer, I ran the Windows driver exe, I opened up my program, changed the programmer and board preferences, hit the "compile & send" button, plugged in my digispark - RGB shield, and then it runs the old sketch.  The dialogue in the editor still said "Plug in device now...".   A strange thing is that it gives the Windows 7 popups that it installed the driver and it works.  It doesn't give the messages (like Comp A) that it failed, then worked, then failed, etc.
So I restarted, and then after another try or two it seems to have worked.
With Comp C I followed the same song and dance and similarly, it seems to be working now.  Here, I used a powered hub.
Again, I got the software, ran the Windows driver exe, started the editor, fixed the settings, loaded my sketch, changed the timing, hit the "compile & run" button, got the message to plug it in, plugged it in, and I got this:
At this point, with the found hardware wizard, from a QA standpoint we have a fork.  First, I try canceling.  The editor doesn't really change or see anything.  However, I do hear the windows sound for a new hardware being found.  In fact, this sound repeats over and over again.  I observed the same thing many times with Comp A.  For what it's worth, it does run the old sketch.
So canceling doesn't work.  Now, we say that we want to specify the location to get the driver from and get Windows to install it.  I specify the Windows driver folder.  It installs, or at least it thinks it does.
Click Finish, and the editor starts to do stuff at last.  But now I hit on something that I think reflects the second problem I had with Comp A.  The editor outputs something very nasty, similar to what I posted from my first try with Comp A.  It gets long so I'm not posting it right now.
So that didn't work.  Now I try it a second time.  This time it works.  This is the output I get.
Binary sketch size: 984 bytes (of a 6,010 byte maximum)
Running Digispark Uploader...
> Device is found!
connecting: 20% complete
connecting: 23% complete
connecting: 27% complete
connecting: 30% complete
connecting: 34% complete
connecting: 40% complete
> Device looks like ATtiny85!
> Whole page count: 94
parsing: 40% complete
parsing: 60% complete
> Erasing the memory ...
erasing: 60% complete
[--CLIPPED--]
erasing: 80% complete
> Starting to upload ...
writing: 80% complete
[--CLIPPED--]
writing: 99% complete
writing: 100% complete
Now it runs the new sketch.
I should summarize I guess.  Here are my major hypotheses that are non-intuitive:
  • There's some kind of driver recognition that has to happen in Windows when you first plug it in, and this is in addition to running the driver install stuff.
  • Even if you get that, the sketch is never sent correctly the first time.  Sometimes you can try again and it'll work and sometimes it will after restart.
  • There's another cause for hangups unrelated to the above two, and I think it's likely to be hardware.  Plugging it in directly to the tower doesn't eliminate this problem.  Everyone (including myself) seems to not have this problem with a powered hub, and my netbook also never showed signs of this problem.  It's likely an issue with the construction of the ports.  With my Comp A it still gets thrown into strange loops of Windows trying to recognize the device even though the driver works occasionally.
