Author Topic: Help with WiFi Settings  (Read 3868 times)
bonehead_1963
  • Guest
« on: June 24, 2014, 01:09:47 pm »
Hi All,
First post as have very recently received my DigiX.
I am trying to get a webpage served from the DigiX and have followed the WiFi setup on the wiki. At the moment I have the board in AP+STA mode with a local IP on STA and can access the settings page from home WiFi. AP has a different IP and still using the DIGIX SSID. I can access the settings page via those settings.
My problem is that I have uploaded a sketch from a previous thread to show pin status and after watching the serial say it's started OK, if I then put in the IP in the browser all I get is the settings page again.
Probably me showing complete ignorance of what I should be doing but any help appreciated.
Ian
Amus3d
Re: Help with WiFi Settings
« Reply #1 on: June 24, 2014, 01:46:37 pm »
ip:8080 for your web page
bonehead_1963
  • Guest
« Reply #2 on: June 24, 2014, 02:30:08 pm »
Thanks, tried that a few times but nothing yet.
How long would you expect to wait for the page to appear as after a couple of resets and reloads it's now sitting there with the waiting for response whirly thing going?
Amus3d
« Reply #3 on: June 25, 2014, 01:47:42 pm »
Upload this code to digiX  board (select board digistump Digix {standard}).
 if yo get an ip address in the Serial Monitor window. and then you type ip:8080 and get nothing migth be a router setting. the port might be block.
#include <DigiFi.h>
DigiFi server;
  Serial.begin(9600);
  server.begin(9600);
 //DigiX trick - since we are on serial over USB wait for character to be entered in serial terminal[pre][left][/left][/pre]
  while(!Serial.available()){
    delay(1000);
  Serial.println("Starting");
  Serial.println("wifi inited");while (server.ready() != 1)
    Serial.println("Error connecting to network");
    delay(15000);
  Serial.println("Connected to wifi!");
  Serial.print("Server running at: ");
  String address = server.server(8080);//sets up server and returns IP
  Serial.println(address);
  if ( server.serverRequest()){
   server.serverResponse("<body>Hello</body>");
« Last Edit: June 25, 2014, 01:52:42 pm by Amus3d »
bonehead_1963
  • Guest
« Reply #4 on: June 28, 2014, 11:26:58 am »
Thanks for that. It did finally work after several resets and quite a long delay in page loading.
Now if I can just get it to serve a file from the SD card......
Cheers,
Ian
