Author Topic: Programming keyboard presses?  (Read 4647 times)
Reon.Balisty
« on: June 14, 2014, 01:45:53 pm »
using digital inputs, I want to make button presses do certain buttons, IE 0='v'  1='SPACE'
anyone can help please?  No help from searching in this site, and want to finish this project soon.
Re: Programming keyboard presses?
« Reply #1 on: June 20, 2014, 05:36:16 am »
Try something like...
#include "DigiKeyboard.h"
// Buttons... pins 3 and 4 are used for USB. You can use any other pins.
uint8_t button1 = 0; // pin number for first button
uint8_t button2 = 1; // pin number for second button
// We'll assume that your button inputs are normally LOW, and go to HIGH when pressed
uint8_t value1 = LOW;
uint8_t value2 = LOW;
  DigiKeyboard.update();
  DigiKeyboard.sendKeyStroke(0); // Some systems seem to need this. You might not.
  pinMode(button1, INPUT);
  pinMode(button2, INPUT);
  value1 = digitalRead(button1);
  value2 = digitalRead(button2);
  if (value1 == HIGH) {
    DigiKeyboard.print("v");
  if (value2 == HIGH) {
    DigiKeyboard.sendKeyStroke(KEY_SPACE);
  // Optional: small delay to allow for button debounce time.
  DigiKeyboard.delay(100);
Note: this is completely untested, but I did at least verify that it compiles.
I gleaned this from searching the forums. I found threads like these:
http://digistump.com/board/index.php/topic,319.0.html
http://digistump.com/board/index.php/topic,366.0.html
http://digistump.com/board/index.php/topic,894.0.html
