Digistump Forums
Back to Digistump.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Digistump Forums
The DigiX
DigiX Support
DigiX not finding I2C decives or reading RX/TX
« previous
next »
Print
Pages:
1
2
Author
Topic: DigiX not finding I2C decives or reading RX/TX (Read 11017 times)
Sr. Member
Re: DigiX not finding I2C decives or reading RX/TX
Reply #15 on:
May 22, 2014, 11:52:53 pm »
All programs using the return code from
Wire.endTransmission()
are currently broken on the DUE/DigiX.
Wire.endTransmission() returns the number of bytes and not an error code, like in the AVR based implementation.
http://forum.arduino.cc/index.php?topic=144700.0
https://github.com/arduino/Arduino/pull/1994
So your scanner-code is not so helpful.
When the EEprom example code works, you might have nothing broken. To drive 5V shield you need an level converter however!
Last Edit: May 23, 2014, 02:18:48 am by gogol
Logged
rholt
Newbie
Reply #16 on:
July 01, 2014, 07:10:53 pm »
This is sort of related to the "possible burned out SDA & SCL pins" on the Digix...
is it possible to check and use the SDA1 & SCL1 pins? if so - how would they be addressed in the script using I2C?
thanks,
Russ from Florida.
Logged
Administrator
Hero Member
Reply #17 on:
July 01, 2014, 09:46:04 pm »
change all references to Wire to Wire1 - including in the libraries being used - so Wire.begin() becomes Wire1.begin() and so on
Logged
Print
Pages:
1
2
« previous
next »
Digistump Forums
The DigiX
DigiX Support
