Hello,
I've gotten past my wifi-hang-on-start issues and have hit a new (hopefully final) wall before I can get into my custom development. I'm using a USB cable, external power supply, the standard Arduino IDE, and the code below. My output window looks like this:
Enter any key to begin
Starting
wifi inited
Connected to wifi!
Server running at: 192.168.1.85
looped 500
[etc]
Note that it seems to start correctly and tells me that the main loop is running (via the "looped 500" message). But also note that it says the server is running at the IP without the specified port. Connecting to that IP works but it's the built-in wifi server, not my custom response. Further, trying to go to 192.168.1.85:8080 gives me a "could not connect" message in Chrome, indicating there is nothing there. I don't get a response from my regular network or if I get onto the DigiX's network and try from there. Both allow me to access the admin screens but not my custom server.
There has got to be a simple answer for this. Any help?
Thanks.
I've tried this code
http://digistump.com/board/index.php/topic,1231.msg5459.html which is pretty much exactly what I want. I had to change the wifi.begin to 115200 from 9600, but the rest of the code as-is.
My "Other Setting" screen looks like this:
http://i.imgur.com/uiEuVc5.png #include <DigiFi.h>
DigiFi wifi;
Serial.begin(9600);
while(!Serial.available()){
delay(1000);
Serial.println("Starting");
wifi.begin(115200);
Serial.println("wifi inited");
while (wifi.ready() != 1)
Serial.println("Error connecting to network");
delay(15000);
Serial.println("Connected to wifi!");
Serial.print("Server running at: ");
String address = wifi.server(8080);//sets up server and returns IP
Serial.println(address);
// wifi.close();
int loopCount = 0;
if ( wifi.serverRequest()){
Serial.print("Request for: ");
Serial.println(wifi.serverRequestPath());
if(wifi.serverRequestPath()!="/")
wifi.serverResponse("404 Not Found",404);
else
wifi.serverResponse("<html><body><h1>This is a test</h1></body></html>"); //defaults to 200
loopCount++;
if (loopCount > 500) {
loopCount = 0;
Serial.println("looped 500");
delay(10);
