Author Topic: PWM issues  (Read 3777 times)
meldrath
PWM issues
« on: March 03, 2014, 12:37:08 am »
When using this code, I'm getting some strange pwm outputs. The leds start to flicker and their brightness is very random while flickering.
I built this library to allow for many led string channels. I'm currently using pins 7 and 8 for pwm.
#ifndef ledChannel_h
#define ledChannel_h
#include "Arduino.h"
class LEDChannel
public:
LEDChannel(uint32_t channel);
void setFade(uint32_t fadeTime);
void setPin(uint32_t pin);
void setTotal(uint32_t totalTime);
void setStart(uint32_t startTime);
void setIntensity(uint32_t intensity);
void setLEDChannel(uint32_t channel, uint32_t pin, uint32_t startTime, uint32_t fadeTime, uint32_t totalTime, uint32_t intensity);
int pwm(int minuntes);
int getPin();
private:
uint32_t _channel;
uint32_t _pin;
uint32_t _startTime;
uint32_t _fadeTime;
uint32_t _totalTime;
uint32_t _intensity;
#endif
#include "ledChannel.h"
LEDChannel::LEDChannel(uint32_t channel)
_channel = channel;
void LEDChannel::setFade(uint32_t fadeTime)
_fadeTime = fadeTime;
void LEDChannel::setPin(uint32_t pin)
_pin = pin;
void LEDChannel::setTotal(uint32_t totalTime)
_totalTime = totalTime;
void LEDChannel::setStart(uint32_t startTime)
_startTime = startTime;
void LEDChannel::setIntensity(uint32_t intensity)
_intensity = intensity;
void LEDChannel::setLEDChannel(uint32_t channel, uint32_t pin, uint32_t startTime, uint32_t fadeTime, uint32_t totalTime, uint32_t intensity)
_channel = channel;
_pin = pin;
int LEDChannel::getPin()
return _pin;
int LEDChannel::pwm(int minutes)
uint32_t pwm = 0;
if (minutes > _startTime || minutes <= (_startTime + _fadeTime))
pwm = map((minutes - _startTime), 0, _fadeTime, 0, _intensity);
if (minutes > ((_startTime + _totalTime) - _fadeTime) && minutes <= (_startTime + _totalTime))
pwm = map((minutes - (_startTime + _totalTime - _fadeTime)), 0, _fadeTime, _intensity, 0);
if (minutes <= _startTime || minutes > _startTime + _totalTime)
if ((_startTime + _totalTime ) % 1440 < _startTime && (_startTime + _totalTime) % 1440 > minutes)
pwm = map(((_startTime + _totalTime) - minutes) % 1440, 0, _fadeTime, 0, _intensity);
else
pwm = 0;
if (pwm > _intensity)
pwm = _intensity;
if (pwm < 0)
pwm = 0;
analogWrite(_pin, map(pwm, 0, 100, 0, 255));
return pwm;
This is the sketch:
#include <ledChannel.h>
#include <rtc_clock.h>
#include <DigiFi.h>
#include <genieArduino.h>
#include <simpleTimer.h>
#define AVERAGEVALUE 5
#define TIMEOUT 10000
#define SENSOR_READ 10000
#define CPU_READ 3000
#define TIME_READ 500
#define LED_READ 15000
#define CHANNELS 16
LEDChannel ledArray[CHANNELS] = {LEDChannel(1), LEDChannel(2), LEDChannel(3), LEDChannel(4), LEDChannel(5), LEDChannel(6),
                                 LEDChannel(7), LEDChannel(8), LEDChannel(9), LEDChannel(10), LEDChannel(11), LEDChannel(12),
                                 LEDChannel(13), LEDChannel(14), LEDChannel(15), LEDChannel(16)};
DigiFi client;
SimpleTimer timer;
RTC_clock rtc_clock(XTAL);
char* dayNames[] = {"", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday", "Sunday"};
char* monthNames[] = {"January", "February", "March", "April", "May", "June", "July", "August", "Septembser", "October", "November", "December"};
int hh, mm, ss, dow, dd, mon, yyyy, currentMM;
char timeServer[] = "time.nist.gov"; // time.nist.gov NTP server
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
uint8_t packetBuffer[NTP_PACKET_SIZE]; // Buffer to hold incoming and outgoing packets
int timeZone = -18; // GMT to Local Time Zone
bool screenSaver = true;
int pos = 0;
float cpuAverage[AVERAGEVALUE];
float orpAverage[AVERAGEVALUE];
float phAverage[AVERAGEVALUE];
float salinityAverage[AVERAGEVALUE];
float sumpTempAverage[AVERAGEVALUE];
float heatsinkTempAverage[AVERAGEVALUE];
float tankTempAverage[AVERAGEVALUE];
uint32_t pwmPinArray[CHANNELS] = {2, 3, 4, 5, 6, 7, 8, 9, 2, 3, 4, 5, 6, 7, 8, 9};
uint32_t startTimeArray[CHANNELS] = {775, 790, 600, 600, 600, 800, 825, 815, 820, 600, 600, 600, 600, 600, 600, 600};
uint32_t fadeTimeArray[CHANNELS] = {60, 60, 120, 120, 120, 120, 120, 120, 120, 120, 120, 120, 120, 120, 120, 120};
uint32_t totalTimeArray[CHANNELS] = {240, 240, 600, 600, 600, 600, 600, 600, 600, 600, 600, 600, 600, 600, 600, 600};
uint32_t intensityArray[CHANNELS] = {100, 100, 100, 40, 40, 70, 90, 100, 100, 100, 100, 40, 40, 30, 100, 100};
// Time and String Manipulation                      *
String hour;
String minute;
String second;
String colon = String(":");
String zero = String("0");
String space = String(" ");
String comma = String(",");
char buf[30] = { "" };
  genieBegin(GENIE_SERIAL_0, 115200); // Digix Serial0
  genieAttachEventHandler(myGenieEventHandler);
  //Reset the Display (change D4 to D2 if you have original 4D Arduino Adaptor)
  pinMode(4, OUTPUT);  // Set D4 on Arduino to Output (4D Arduino Adaptor V2 - Display Reset)
  digitalWrite(4, 1);  // Reset the Display via D4
  delay(100);
  digitalWrite(4, 0);  // unReset the Display via D4
  delay(3500); //let the display start up
  genieWriteContrast(15); // 1 = Display ON, 0 = Display OFF
  genieWriteStr(0, "Initializing Wi-Fi");
  delay(500);
  client.begin(115200); //Wifi Connect
  rtc_clock.init();
  client.setMode(UDP); //must come before connect
  genieWriteStr(0, "Initializing RTC via NTP");
  delay(500);
  client.connect(timeServer, 123);
  unsigned long ntpUnixTime = 0;
  while (ntpUnixTime == 0)
    genieWriteStr(0, "Sending packet");
    sendNTPpacket(); // send an NTP packet to a time server
    delay(2000);
    genieWriteStr(0, "Reading packet");
    ntpUnixTime = getNTPpacket();
  rtc_clock.set_timestamp(ntpUnixTime);
  checkTimeZone();
  printTime();
  printDate();
  cpuTemp();
  setupLED();
  timer.setInterval(TIME_READ, timeLord);
  timer.setInterval(CPU_READ, cpuTemp);
  timer.setInterval(TIMEOUT, checkTimeout);
  timer.setInterval(LED_READ, checkLED);
  genieDoEvents();
  timer.run();
void myGenieEventHandler(void)
  bool screenSaver = false;
  timer.restartTimer(2);
  genieFrame Event;
  genieDequeueEvent(&Event);
  if (genieEventIs(&Event, GENIE_REPORT_EVENT, GENIE_OBJ_FORM, 0)) // Returning to the home screen reprint time/date.
    cpuTemp();
    printDate();
    printTime();
  if (genieEventIs(&Event, GENIE_REPORT_EVENT, GENIE_OBJ_FORM, 1))
void timeLord()
  currentMM = mm;
  rtc_clock.get_time(&hh, &mm, &ss);
  if (currentMM != mm) //Prevent redraw on every timer interval
    printTime();
  if (hh == 0 && mm < 1 && ss < 5) //Print date at midnight
    rtc_clock.get_date(&dow, &dd, &mon, &yyyy);
    printDate();
    updateNTP();
void setupLED()
  for (int i = 0; i < CHANNELS; i++)
    ledArray[i].setLEDChannel(i, pwmPinArray[i], startTimeArray[i], fadeTimeArray[i], totalTimeArray[i], intensityArray[i]);
  String temp;
  temp = String(ledArray[3].getPin());
  temp.toCharArray(buf, 4);
  genieWriteStr(3, buf);
  temp = String(ledArray[5].getPin());
  genieWriteStr(4, buf);
void checkLED()
  int minutes = (hh * 60) + mm;
  int test = ledArray[5].pwm(minutes);
  int test2 = ledArray[6].pwm(minutes);
  String temp;
  temp = String(test);
  temp = String(test2);
void updateNTP()
void checkTimeout()
  if (screenSaver = true)
    genieWriteContrast(1);
  screenSaver = true;
unsigned long sendNTPpacket()
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12] = 49;
  packetBuffer[13] = 0x4E;
  packetBuffer[14] = 49;
  packetBuffer[15] = 52;
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  client.write(packetBuffer, NTP_PACKET_SIZE);
unsigned long getNTPpacket() {
  if (client.available())
    // We've received a packet, read the data from it
    client.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
    //the timestamp starts at byte 40 of the received packet and is four bytes,
    // or two words, long. First, esxtract the two words:
    unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
    unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
    // combine the four bytes (two words) into a long integer
    // this is NTP time (seconds since Jan 1 1900):
    unsigned long secsSince1900 = highWord << 16 | lowWord;
    //Serial.print("Seconds since Jan 1 1900 = " );
    //Serial.println(secsSince1900);
    // now convert NTP time into everyday time:
    //Serial.print("Unix time = ");
    // Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
    const unsigned long seventyYears = 2208988800UL;
    // subtract seventy years:
    unsigned long epoch = secsSince1900 - seventyYears;
    // print Unix time:
    return epoch;
  else
    return 0;
void printTime()
  String temp;
  if (hh < 10)
    hour = String(zero + hh);
  else
    hour = String(hh);
  if (mm < 10)
    minute = String(zero + mm);
  else
    minute = String(mm);
  temp = String(hour + colon + minute);
  temp.toCharArray(buf, 10);
  genieWriteStr(1, buf);
void printDate()
  String temp;
  if (dd > 31)
     dd = 0;
  temp = String(dayNames[rtc_clock.get_day_of_week()] + comma + space + monthNames[mon - 1] + space + dd + comma + space + yyyy);
  temp.toCharArray(buf, 30);
  genieWriteStr(0, buf);
void checkTimeZone()
  uint16_t year = yyyy;
  hh = hh + timeZone;
  if (hh < 0)
    hh = hh + 24;
    dd = dd - 1;
    dow = dow - 1;
    if (dd < 1)
      mon = mon - 1;
      if (mon < 0)
        mon = 12;
        yyyy = yyyy - 1;
  rtc_clock.set_time(hh, mm, ss);
  rtc_clock.set_date(dd, mon, yyyy);
void cpuTemp()
  String temp;
  float currTemp = 0;
  adc_enable_ts(ADC);
  adc_enable_channel( ADC, adc_channel_num_t(15) );
  adc_start(ADC);
  while ((adc_get_status(ADC) & ADC_ISR_DRDY) != ADC_ISR_DRDY);
  currTemp = (0.304025390625 * adc_get_latest_value(ADC)) - 274, 89;
  temp = String(takeAverage(currTemp, pos, cpuAverage));
  temp.toCharArray(buf, 5);
  genieWriteStr(5, buf);
  if (pos > 4)
    pos = 0;
  else
    pos++;
float takeAverage(int value, int index, float average[])
  float holder = 0.0;
  String test = "";
  int division = AVERAGEVALUE;
  if (value < 0)
    average[index] = 0.0;
  else
    average[index] = value;
  for (int i = 0; i < AVERAGEVALUE; i++)
    if (average[i] == 0.0 && division > 1)
      division--;
    holder += average[i];
  holder = holder / division;
  return holder;
I'm using a custom screen, so any output can be changed to serial for debugging. I'm just wondering if anyone with some pwm lights can test my pwm code and see if they get the same weird results I'm getting.
« Last Edit: March 03, 2014, 12:39:35 am by meldrath »
meldrath
Re: PWM issues
« Reply #1 on: March 11, 2014, 08:52:00 pm »
Can anyone try my library out, and see if its the library or my due?
