Digistump Forums
Back to Digistump.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Digistump Forums
The DigiX
DigiX Support
Level-Shifter use?
« previous
next »
Print
Pages:
1
2
Author
Topic: Level-Shifter use? (Read 12367 times)
Administrator
Hero Member
Re: Level-Shifter use?
Reply #15 on:
February 05, 2014, 05:35:13 pm »
Have you tried connecting the DHT22 to the DigiX directly and the VCC for it to 3.3v instead of 5v - it looks like it can run at 3.3v as well and not need the shifter - that could answer if it is a timing, code, etc issue
Logged
Techno
Newbie
Reply #16 on:
February 05, 2014, 06:05:06 pm »
Think I have tried 3,3 Volt with the DHT22 and no Level-Shifting Shield. Will try it again tomorrow.
I have been in contact with Rob Tillaart over at forum.arduino.cc. He has had me try a couple of things. Still not yet working.
Will continue trying suggestions.
I ordered a new DHT22 sensor for testing purpose.
William
Logged
Techno
Newbie
Reply #17 on:
February 06, 2014, 03:24:12 pm »
@digistump
You were right. DHT22 works @ 3.3 Volts without level-Shifter Shield on A3! Sketch I uploaded; changed DHT22 pin to pin A11, DHT22 powered by 3.3 Volts. Using Level-Shifter Shield for I2C bus @ 5 Volts for DS1307 and BMP085 (Model BY-065 -- 5 Volt regulator on breakout board.) --Both are I2C devices.
William
Last Edit: February 06, 2014, 03:30:54 pm by Techno
Logged
Print
Pages:
1
2
« previous
next »
Digistump Forums
The DigiX
DigiX Support
Level-Shifter use?
