Author Topic: [solved]Problem with code. TinySoftPWM shoud work, isn't.  (Read 3817 times)
Dupl3xxx
« on: January 19, 2014, 06:13:30 pm »
I'm trying to create a "rainbow" effect with all 6 pins on the digispark. I want the led's to become brighter, then darker. The code should work, but isn't. Anyone see the misstake I made?
This is the effect I'm trying to achive:
code:
#include <TinySoftPwm.h>
int value[] = {
  0,43,86,129,152,193};
boolean rising[] = {
  true,true,true,true,true,true};
  TinySoftPwm_begin(128, 0); /* 128 x TinySoftPwm_process() calls before overlap (Frequency tuning), 0 = PWM init for all declared pins */
  static uint32_t StartUs=micros();
  static uint32_t StartMs=millis();
  static uint8_t Pwm=0;
  static int8_t  Dir=1;
  /* Call TinySoftPwm_process() with a period of 60 us       */
  /* The PWM frequency = 128 x 60 # 7.7 ms -> F # 130Hz      */
  /* 128 is the first argument passed to TinySoftPwm_begin() */
  if((micros() - StartUs) >= 60)
    /* We arrived here every 60 microseconds */
    StartUs=micros();
    TinySoftPwm_process(); /* This function shall be called periodically (like here, based on micros(), or in a timer ISR) */
  /* Increment/decrement PWM on LED Pin with a period of 10 ms */
  if((millis()-StartMs) >= 10)
    /* We arrived here every 10 milliseconds */
    StartMs=millis();
    /* for each of the 6 pins*/
    for (int i = 0; i < 6; i++)
      if(rising[i])
        value[i]++;
        if(value[i] == 256)
          rising[i] = false;
          value[i] = 254;
      else
        value[i]--;
        if(value[i] == -1)
          rising[i] = true;
          value[i] = 1;
      TinySoftPwm_analogWrite(value[i], i);
Thanks DeuxVis for the code tag :)
TinySoftPwm_analogWrite(PIN, VALUE) -> TinySoftPwm_analogWrite(VALUE, PIN)
« Last Edit: January 20, 2014, 12:51:03 pm by Dupl3xxx »
Re: Problem with code. TinySoftPWM shoud work, isn't.
« Reply #1 on: January 20, 2014, 02:53:53 am »
if(rising) might work better as if(rising[ i ])
And that 'i' might help in other array spots too.
« Last Edit: January 20, 2014, 10:08:50 am by defragster »
DeuxVis
« Reply #2 on: January 20, 2014, 03:03:14 am »
You probably wanted to write
rising[i]
anywhere there is only
rising
otherwise only the first element of that rising array will ever be used.
Sorry for duplicating your comment defragster, but without the
[code] tag it is difficult to read :)
« Reply #3 on: January 20, 2014, 10:10:01 am »
Code tag helps - was there a real problem that is fixed - or was the code just getting hosed on POST?
Dupl3xxx
« Reply #4 on: January 20, 2014, 12:50:13 pm »
Found the problem:
and not
Swithed those around, and now it works! :D
