Author Topic: Interfacing the Digix to a 4D systems 43PT Display  (Read 3307 times)
meldrath
« on: January 10, 2014, 01:20:07 am »
I've tried using their Arduino library that works with the due (commented out the appropriate line), but all of my serial commands only seem to go to the Serial Monitor and not the LCD.
Thank you
Re: Interfacing the Digix to a 4D systems 43PT Display
« Reply #1 on: January 10, 2014, 01:35:59 am »
Replace Serial with Serial0
Because the DigiX uses Native USB Serial instead of the second programming port the Due has, but we still want to make it compatible with most sketches which assume the serial monitor is on Serial not SerialUSB - we changed it as follows:
Due          DigiX
Serial       Serial0
SerialUSB    Serial or SerialUSB
Serial1      Serial1
Serial2      Serial2
You can also just select the Due as the board instead of the DigiX and it will work just fine with the Due mappings - WiFi and other DigiX specific features may not work though.
meldrath
« Reply #2 on: January 10, 2014, 10:25:28 am »
Finally got it. Thank you for your help, wouldn't have gotten there if it wasn't for that :D :D :D
meldrath
« Reply #3 on: January 11, 2014, 11:54:41 pm »
To anyone interested, I've updated the code for the 4d systems visi genie library (great screens btw) to work with the digix. (just a few simple lines)
https://github.com/Meldrath/ViSi-Genie-Arduino-Library
Thank you digistump (erik) for helping me solve my initial issue.
