Author Topic: Testing WiFi module via TCPUDPDbg  (Read 5208 times)
Nir H@im
« on: December 26, 2013, 12:43:03 pm »
Hi everyone,
I'm trying to create TCP/UDP connection between WiFi and my android/my comp.
Does any one succeed to make it work?
Also in datasheet i found that command "AT+UDPPRO" only supported in FIRMWARE V1.5.2 ,
while our FW 1.4.4.
Another question, what is the different between SOCKET A and B?? What commands are necessary to make a TCP connection valid and which order?
Thanks for any response,
Nir.
TimO
Re: Testing WiFi module via TCPUDPDbg
« Reply #1 on: December 30, 2013, 08:17:28 am »
Which datasheet are you using?  I'm reading "Low Power WiFi Module User Manual (USR-WIFI232-G) V 1.3", and there's no mention of that command in it.
Mushon
« Reply #2 on: December 30, 2013, 01:12:22 pm »
Hi there is V1.7 on their web site - see page 44
http://www.tcp232.net/usr-download.html
TimO
« Reply #3 on: December 30, 2013, 04:20:40 pm »
I can't see any documents on that page with a Version number of 1.7 (or anything else which seems plausible).  Can you give the URL of the actual document?
