wilscott -
Do you have multiple Digisparks? If so can you try another?
Can you also try on a second machine if possible?
And, if you have a power supply over 7v can you try powering it by the VIN pin and then check if you get 5v between 5v and ground.
Voltage drop should only be about 0.3v - so let me know if you can try any of those things, especially testing with another Digispark if you have another, and we\'ll get it solved.
