Here's my current code that appears to work as I expect and loops round all the patterns.
Just need to work out the most efficient way of showing the light patterns.
Ben
Debounce
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Debounce
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 5; // the number of the pushbutton pin
const int flPin = 0; // Front left strip
const int frPin = 1; // Front right strip
const int rlPin = 2; // Rear left strip
const int rrPin = 3; // Rear right strip
const int tailPin = 4; // Tail strip
const int pattern_num = 3; // Number of light patterns we have defined
// Variables will change:
//int FL = LOW; // the current state of the output pin
//int FR = LOW; // the current state of the output pin
//int RL = LOW; // the current state of the output pin
//int RR = LOW; // the current state of the output pin
//int TAIL = LOW; // the current state of the output pin
int ledState = LOW; //initial state of led's
int buttonState; // the current reading from the input pin
int lastButtonState = LOW; // the previous reading from the input pin
int pattern = 0; // tracks which pattern we're on
// the following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 50; // the debounce time; increase if the output flickers
pinMode(buttonPin, INPUT);
pinMode(flPin, OUTPUT);
pinMode(frPin, OUTPUT);
pinMode(rlPin, OUTPUT);
pinMode(rrPin, OUTPUT);
pinMode(tailPin, OUTPUT);
// set initial LED state
digitalWrite(flPin, ledState);
digitalWrite(frPin, ledState);
digitalWrite(rlPin, ledState);
digitalWrite(rrPin, ledState);
digitalWrite(tailPin, ledState);
// read the state of the switch into a local variable:
int reading = digitalRead(buttonPin);
// check to see if you just pressed the button
// (i.e. the input went from LOW to HIGH), and you've waited
// long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
// if the button state has changed:
if (reading != buttonState) {
buttonState = reading;
// only increment the pattern counter if the new button state is HIGH and the pattern number is less than the number of patterns
if (buttonState == HIGH && pattern < (pattern_num + 1)) {
pattern++;
if (pattern == 4) {
pattern = 0;
// save the reading. Next time through the loop,
// it'll be the lastButtonState:
lastButtonState = reading;
// now run some light shows
switch(pattern){
case 0:
// turn all LED's OFF
digitalWrite(flPin, LOW);
digitalWrite(frPin, LOW);
digitalWrite(rlPin, LOW);
break;
case 1:
digitalWrite(flPin, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(frPin, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(rlPin, HIGH); // turn the LED on (HIGH is the voltage level)
delay(500); // wait half a second and turn LED off
break;
case 2:
digitalWrite(flPin, HIGH); // turn the LED on by making the voltage HIGH
delay(200);
digitalWrite(flPin, LOW); // turn the LED off by making the voltage LOW
digitalWrite(frPin, HIGH); // turn the LED on by making the voltage HIGH
delay(200);
digitalWrite(frPin, LOW); // turn the LED off by making the voltage LOW
digitalWrite(rlPin, HIGH); // turn the LED on by making the voltage HIGH
delay(200);
break;
case 3:
delay(200);
digitalWrite(rlPin, LOW); // turn the LED off by making the voltage LOW
delay(200);
delay(200);
break;
default:
