Author Topic: auto reset  (Read 3322 times)
bobricius
auto reset
« on: December 29, 2012, 01:13:35 am »
Hi is possible to add any autoreset feature?
« Last Edit: December 29, 2012, 01:13:35 am by bobricius »
auto reset
« Reply #1 on: December 29, 2012, 10:23:31 pm »
I don\'t believe this is technically possible, at least not with the current bootloader, but likely not with any. You could of course have your program (thru an i/o pin) cut power to the board and then the pin would shut off allowing power back to it.
duckythescientist
auto reset
« Reply #2 on: December 29, 2012, 11:12:21 pm »
An option that should work: set the watchdog timer to the shortest time then while(1); to get it stuck. It should restart into the bootloader.
auto reset
« Reply #3 on: December 30, 2012, 02:39:19 am »
It\'s not possible, though you could make your program reboot in to the bootloader like ducky said. The digispark arduino software doesn\'t have any built in feature to send a \'please reboot\' command to already booted digisparks though.
I think it\'s better this way - unplugging and plugging back in is a nice clear way to specify which digispark it is you want the program to upload in to, if you have more than one on your computer (I have three already!!)
