Author Topic: DIP Socket Shield  (Read 4796 times)
cboden
DIP Socket Shield
« on: July 27, 2013, 07:19:53 am »
What about a shield that would allow to insert a Digispark into 16 pin (or more/less) DIP socket? It would allow to build greater circuits on larger (bread-) boards and simply add or remove the Digispark. Then It would be easy to re-programm it for example. Afterwards you can press the Digispark into the socket again. This would also allow to use standard breadboards more easily.
Re: DIP Socket Shield
« Reply #1 on: July 27, 2013, 06:27:51 pm »
Just buy some attiny85 chips! You can even use a digispark to program them in place using the LittleWire firmware as an ISP programmer.
