What about a shield that would allow to insert a Digispark into 16 pin (or more/less) DIP socket? It would allow to build greater circuits on larger (bread-) boards and simply add or remove the Digispark. Then It would be easy to re-programm it for example. Afterwards you can press the Digispark into the socket again. This would also allow to use standard breadboards more easily.
