The digispark is a USB-ISP-programmer:
as soon, as you have installed littlewire, it acts like the USBtinyISP (as it is one hardware wise)
As littlewire is a c-application you can't install it from the arduino-IDE. So you need to install either the precompiled binary, which is in hex-format, or you can download the sources from littlewire and compile it with the avr-toolchain (you already have in your arduino-directory)
Installation is very simple: You need to call the micronucleus binary (micronucleus.exe for Windows) with the full path to the littlewire-HEX-File.
The only difference is, that if you buy an littlewire comes already preloaded and has the PINs for connecting the victim arranged in the Atmel 3x2 design (and it has an real USB-plug, not only the PCB)
http://littlewire.cc/
